Restoring a Majestic 20 NEED HELP PLEASE
11/12/2008 5:39:47 PMG. Berg
Hi all I am restoring a Majestic model 20 and could use some help from those that restored this particular set. It has a "lovely" block of capacitors sealed in tar (That I want to replace) The 4 leads comming out are clearly color coded (2mf, 2mf, 1mf 1mf .07(and on the schematic). The block has 10 lugs..and can determine where all color wires go to ...so I can replace the caps..but when I lifted the top of bock/can off am not able to tell what all other wires (6 of them) underneath are for ..They go to other six lugs on top...any help?? PLEASE (By the way...I have lugs numbered 1-10 ..number one being the white wire. OR BETTER YET ANYONE HAVE A PARTS LIST FOR THIS RADIO?? I could figure out if that is available..This particular block in # 3887 THANKS FOR ANY HELP YOU CAN GIVE!!
11/12/2008 5:50:00 PMG. Berg THANKS LOU!!
THANKS LOU!! My question was answered by LOU...GREAT HELP!!!
:Hi all I am restoring a Majestic model 20 and could use some help from those that restored this particular set. It has a "lovely" block of capacitors sealed in tar (That I want to replace) The 4 leads comming out are clearly color coded (2mf, 2mf, 1mf 1mf .07(and on the schematic). The block has 10 lugs..and can determine where all color wires go to ...so I can replace the caps..but when I lifted the top of bock/can off am not able to tell what all other wires (6 of them) underneath are for ..They go to other six lugs on top...any help?? PLEASE (By the way...I have lugs numbered 1-10 ..number one being the white wire. OR BETTER YET ANYONE HAVE A PARTS LIST FOR THIS RADIO?? I could figure out if that is available..This particular block in # 3887 THANKS FOR ANY HELP YOU CAN GIVE!!
