I need a schematic for an Admiral A126 or at least the values of the filter capaciters
12/5/2000 2:30:24 PMJohn McPherson(6735:6734)
Hi, Caps of about 10Mfd should work fine.
It is not listed in Rider's, but it is a 1937 vintage. If you can find the 450 working volt caps, these would be the best choice.
: I need a schematic for an Admiral A126 or at least the values of the filter capaciters
12/6/2000 1:56:31 PMRichard(6740:6734)
: I need a schematic for an Admiral A126 or at least the values of the filter capaciters Peter, You can get the Capacitors at Antique Electronic Supply for about $1.30 ea. They have an on-line catalogue at www.tubesandmore.com. Good luck.
