Schematic for Sparton 6CL66
11/10/2008 8:06:23 AMMike C
Can't find a schematic for this radio anywhere. Any help would be greatly appreciated.
11/10/2008 8:52:34 AMCarl T
:Can't find a schematic for this radio anywhere. Any help would be greatly appreciated.
Mike,
This schematic should be close:
http://www.nostalgiaair.org/PagesByModel/832/M0018832.pdf
Carl T
11/10/2008 8:55:34 AMMike M
::Can't find a schematic for this radio anywhere. Any help would be greatly appreciated.
:Mike,
:This schematic should be close:
:http://www.nostalgiaair.org/PagesByModel/832/M0018832.pdf
:Carl T
Mike,
I just finished one of these. I used the schematic Carl mentions. It is very close. If I remember correctly, the 6CL66 has one more trimmer than the 6-66.
Mike
11/10/2008 3:47:42 PMMike C
:::Can't find a schematic for this radio anywhere. Any help would be greatly appreciated.
::Mike,
::This schematic should be close:
::http://www.nostalgiaair.org/PagesByModel/832/M0018832.pdf
::Carl T
:Mike,
:I just finished one of these. I used the schematic Carl mentions. It is very close. If I remember correctly, the 6CL66 has one more trimmer than the 6-66.
:Mike
:Thanks, that solved oone of the issues with a paper cap that only had a part number on it. I don't seem to have any power to the transformer at the speaker so I need to look at the E caps and 2 resistors in that area of the chassis. All tubes light up as does the dial lamp. Will just keep on checking....
11/11/2008 5:24:07 PMMike C
::::Can't find a schematic for this radio anywhere. Any help would be greatly appreciated.
:::Mike,
:::This schematic should be close:
:::http://www.nostalgiaair.org/PagesByModel/832/M0018832.pdf
:::Carl T
::Mike,
::I just finished one of these. I used the schematic Carl mentions. It is very close. If I remember correctly, the 6CL66 has one more trimmer than the 6-66.
::Mike
::Thanks, that solved oone of the issues with a paper cap that only had a part number on it. I don't seem to have any power to the transformer at the speaker so I need to look at the E caps and 2 resistors in that area of the chassis. All tubes light up as does the dial lamp. Will just keep on checking....
:Just a follow up. Radio is up and working on AM and SW. Thanks again for the guidance and helpful follow ups. Mike
