It sure sounds like a dirty mechanical leaf switch. Some radios have this simple mute switch. If it gets dirty it will act just that way ..
:Dave
::Hello All,
:: I'm working on a Becker Mexico TR. When I press the seek bar, it works and stops at the next strongest stations, but it wont un-mute all the time. Also sometimes if I wait, it will un-mute. But it just takes too long. If I move keep pressing the seek button, at some point it will un mute after finding a station.
:: Any suggestions about what's going on?
::Thanks,
:It sure sounds like a dirty mechanical leaf switch. Some radios have this simple mute switch. If it gets dirty it will act just that way ..
::Dave
Don't know the model you have. If there is a mechanical switch, it might be in the motor box. See if there is any wires going from the mechanical drive motor works to the amp or detector circuits .. If not then it must be electronic mute. A dry cap would act this lazy way ass well ..
::Warren,
:: So where is this switch? I have searched the radio but cannot find it in this model.
::Thanks,
::Dave
::::Hello All,
:::: I'm working on a Becker Mexico TR. When I press the seek bar, it works and stops at the next strongest stations, but it wont un-mute all the time. Also sometimes if I wait, it will un-mute. But it just takes too long. If I move keep pressing the seek button, at some point it will un mute after finding a station.
:::: Any suggestions about what's going on?
::::Thanks,
:::It sure sounds like a dirty mechanical leaf switch. Some radios have this simple mute switch. If it gets dirty it will act just that way ..
::::Dave
:Don't know the model you have. If there is a mechanical switch, it might be in the motor box. See if there is any wires going from the mechanical drive motor works to the amp or detector circuits .. If not then it must be electronic mute. A dry cap would act this lazy way ass well ..
Check out the mark up submitted for some possibilities.
Initially. . . . der is bin schmitt der Zugmagnet. . . or the tuning solenoid driver mechanism at the [ A ] referencing with its
R/C pair of R5-C6 [ C ], with C6 being the sole suspect of the two, IF there is fault in the full loading of the tuning solenoid.
Auto-tuning / triggering will be accomplished with your tuning relay [ B ] with its starting and stopping function of the tuning, initiated
from a DC sampling at the start of the green line path and then into the trio of DC coupled xstr amplifiers at T-401-403-403,
with the final 403 driving the relay.
On the power supply portion of the tuning system, check out filter caps [ D ] and [ E ] .
Check the trim resistor R404 [ F ] for sensitivity / delay setting.
Pee Ess. . . .Wherein doth this Liliputian, magnificient engineering marvel (for its time) reside, perchance, posssibly, within the dash environs of some classic Mercy Days ?
Working Schema Thumbnail:
(FIO. . . .S-3 Solenoid return switch )
:Check out the mark up submitted for some possibilities.
:Initially. . . . der is bin schmitt der Zugmagnet. . . or the tuning solenoid driver mechanism at the [ A ] referencing with its
:R/C pair of R5-C6 [ C ], with C6 being the sole suspect of the two, IF there is fault in the full loading of the tuning solenoid.
:Auto-tuning / triggering will be accomplished with your tuning relay [ B ] with its starting and stopping function of the tuning, initiated
:from a DC sampling at the start of the green line path and then into the trio of DC coupled xstr amplifiers at T-401-403-403,
:with the final 403 driving the relay.
:On the power supply portion of the tuning system, check out filter caps [ D ] and [ E ] .
:Check the trim resistor R404 [ F ] for sensitivity / delay setting.
:Pee Ess. . . .Wherein doth this Liliputian, magnificient engineering marvel (for its time) reside, perchance, posssibly, within the dash environs of some classic Mercy Days ?
:Working Schema Thumbnail:
:(FIO. . . .S-3 Solenoid return switch )
Hmmmm. . . .that do be velly, velly strange. . . . for I am sitting here after just successfully pulling it upon on three different
interconnect modes, via . . . .Explorer,"Godzilla†and even Netscape.
Here is a full and valid direct URL I.D. for its routing:
Here. . .HERE. . . I'm right 'CHERE
Bob Eeeeeeeeeee:
Thank yuh, Thank yuh. . . . .thank yuh very much. . . .a la Elvis-esque.
