SONY CRF-150 Schematic
11/7/2008 5:23:49 PMEdd
Hmmmm. . .seems like that enlarged schema size impinged upon the hosting sites upper limit, so, herewith a J-peg of same, with
a wee bit of a loss of resolution on fine detail, in case the prior PNG fails to come up for you.. . .as it has only came up once for me, now maybe the "thoid" times a charm ?after extracting the errant single quote in the HTML coding.
11/8/2008 2:42:06 PMDennis C.
:Hmmmm. . .seems like that enlarged schema size impinged upon the hosting sites upper limit, so, herewith a J-peg of same, with
:a wee bit of a loss of resolution on fine detail, in case the prior PNG fails to come up for you.. . .as it has only came up once for me, now maybe the "thoid" times a charm ?after extracting the errant single quote in the HTML coding.
11/9/2008 11:40:00 AMDr.T.
::Hmmmm. . .seems like that enlarged schema size impinged upon the hosting sites upper limit, so, herewith a J-peg of same, with
::a wee bit of a loss of resolution on fine detail, in case the prior PNG fails to come up for you.. . .as it has only came up once for me, now maybe the "thoid" times a charm ?after extracting the errant single quote in the HTML coding.
::73's de Edd
Thank you. This seems to be the correct one. I am repairing it simply due to its quality design and construction. The bandswitch is a work or art containing 5 ganged turrents on a shaft similar to early vhf TV tuners --it is also dual conversion.
Thanks again.
