182B/482B source
11/7/2008 3:07:30 PMMike M
Does anyone have a source for a 182B/482B? I've tried radiodaze and Tubes and More and a few others that came up on google. I need to replace one in a Sparton Jr. that has an intermittant filament.
Thanks.
Mike M
11/7/2008 3:51:46 PMRadiodoc
Mike M.,
You might try heating the filament pins (1 & 4) and remove the old solder and reapply fresh solder to the pins. I have found a few times in the past that some tubes I had had intermittent filaments and I found the wire from the tube filament to tube pin wasn't making good contact anymore and after resoldering the intermittent was solved.
:Does anyone have a source for a 182B/482B? I've tried radiodaze and Tubes and More and a few others that came up on google. I need to replace one in a Sparton Jr. that has an intermittant filament.
:Thanks.
:Mike M
11/8/2008 12:31:31 AMLou
WHat type of tube is this?
I do not recodnize the number.
Lou
:Mike M.,
:You might try heating the filament pins (1 & 4) and remove the old solder and reapply fresh solder to the pins. I have found a few times in the past that some tubes I had had intermittent filaments and I found the wire from the tube filament to tube pin wasn't making good contact anymore and after resoldering the intermittent was solved.
:Radiodoc
::Does anyone have a source for a 182B/482B? I've tried radiodaze and Tubes and More and a few others that came up on google. I need to replace one in a Sparton Jr. that has an intermittant filament.
::Thanks.
::Mike M
11/8/2008 12:50:41 AMLou
Looking it up in the database here, it looks like a UX 171A is a substitute, for parallel filament operation only.
The '71A is a much more common tube to find.
Lou
:WHat type of tube is this?
:I do not recodnize the number.
:Thanks
:Lou
::Mike M.,
::You might try heating the filament pins (1 & 4) and remove the old solder and reapply fresh solder to the pins. I have found a few times in the past that some tubes I had had intermittent filaments and I found the wire from the tube filament to tube pin wasn't making good contact anymore and after resoldering the intermittent was solved.
::Radiodoc
:::Does anyone have a source for a 182B/482B? I've tried radiodaze and Tubes and More and a few others that came up on google. I need to replace one in a Sparton Jr. that has an intermittant filament.
:::Thanks.
:::Mike M
11/8/2008 4:13:02 PMMike M
Thanks guys. I never thought about resoldering the pins or using a 71A as a substitute.
:Looking it up in the database here, it looks like a UX 171A is a substitute, for parallel filament operation only.
:The '71A is a much more common tube to find.
:Lou
::WHat type of tube is this?
::I do not recodnize the number.
::Thanks
::Lou
:::Mike M.,
:::You might try heating the filament pins (1 & 4) and remove the old solder and reapply fresh solder to the pins. I have found a few times in the past that some tubes I had had intermittent filaments and I found the wire from the tube filament to tube pin wasn't making good contact anymore and after resoldering the intermittent was solved.
:::Radiodoc
::::Does anyone have a source for a 182B/482B? I've tried radiodaze and Tubes and More and a few others that came up on google. I need to replace one in a Sparton Jr. that has an intermittant filament.
::::Thanks.
::::Mike M
