Crosley
11/6/2008 8:02:51 PMVinny
Greetings, I have a Crosley 11-100U. While testing the tubes I pulled out the 50C5 tube and out came the the metal from the socket that the #2pin (I think the #2pin)goes into, it was stuck to the #2pin. My question because I am having a problem reading the schematic is: Does that pin have any function? I read it as it does not. Can someone please confirm that so I may not have to change the entire socket.
Thank you,
Vinny A.
11/6/2008 8:17:57 PMBob E
http://www.nostalgiaair.org/tubes/50c5.htm
Looks to me that pin two goes to the grid which
would indeed have a function... others more knowing can correct me if I am wrong.
Bob E.
:Greetings, I have a Crosley 11-100U. While testing the tubes I pulled out the 50C5 tube and out came the the metal from the socket that the #2pin (I think the #2pin)goes into, it was stuck to the #2pin. My question because I am having a problem reading the schematic is: Does that pin have any function? I read it as it does not. Can someone please confirm that so I may not have to change the entire socket.
:Thank you,
:Vinny A.
11/6/2008 8:18:18 PMnom
Can't you just look at the plug underneath and see if there's a wire to that socket?...Neal
:Thank you,
:Vinny A.
11/6/2008 8:37:58 PMvinny
there does not appear to be any loose wires.
Vinny
:Can't you just look at the plug underneath and see if there's a wire to that socket?...Neal
::Greetings, I have a Crosley 11-100U. While testing the tubes I pulled out the 50C5 tube and out came the the metal from the socket that the #2pin (I think the #2pin)goes into, it was stuck to the #2pin. My question because I am having a problem reading the schematic is: Does that pin have any function? I read it as it does not. Can someone please confirm that so I may not have to change the entire socket.
::Thank you,
::Vinny A.
11/6/2008 8:50:48 PMBill VA
Is there cap and resistor going to Pin 2? What's connected to pin 5? If pin 2 you have an open within the socket, no audio coupling.
Bill
:there does not appear to be any loose wires.
:Vinny
::Can't you just look at the plug underneath and see if there's a wire to that socket?...Neal
:::Greetings, I have a Crosley 11-100U. While testing the tubes I pulled out the 50C5 tube and out came the the metal from the socket that the #2pin (I think the #2pin)goes into, it was stuck to the #2pin. My question because I am having a problem reading the schematic is: Does that pin have any function? I read it as it does not. Can someone please confirm that so I may not have to change the entire socket.
:::Thank you,
:::Vinny A.
11/6/2008 9:00:19 PMBill VA
When all else fails look at the schematic...according to voltage chart for the tubes, no connection to pin 2. You should check but your're ok.
Bill
:Is there cap and resistor going to Pin 2? What's connected to pin 5? If pin 2 you have an open within the socket, no audio coupling.
:Bill
::there does not appear to be any loose wires.
::Vinny
:::Can't you just look at the plug underneath and see if there's a wire to that socket?...Neal
::::Greetings, I have a Crosley 11-100U. While testing the tubes I pulled out the 50C5 tube and out came the the metal from the socket that the #2pin (I think the #2pin)goes into, it was stuck to the #2pin. My question because I am having a problem reading the schematic is: Does that pin have any function? I read it as it does not. Can someone please confirm that so I may not have to change the entire socket.
::::Thank you,
::::Vinny A.
11/6/2008 9:02:53 PMWarren
:Bill
::Vinny
::::Thank you,
::::Vinny
Pin #2 & pin #5 are both connected to the same grid inside the tube itself .. If nothing was connected to pin #2 of the socket, it's all connected to Pin #5 ..
Put the tube back in .. Should play fine
