Setchell-Carlson 613B Schematic
12/2/2000 10:53:00 AMBob Norman
I am trying to restore a Setchell-Carlson 613B amplifier. Does anyone have a schematic or other information about this amplifier (such as when it was made, etc). All help appreciated!
12/2/2000 12:30:49 PMJohn McPherson
Have you looked at the model 13 PA Amp?
http://ww3.nostalgiaair.org/schematics/SCI/_SCI_8-1.gif (about 1937/1938)
If that is not the same, there may not be a schematic available.
Sams only lists a 611, in folder 329,(which dates it to about 1956/1957) but the S.C. model Idents leave a bit to be desired.
Short of extrapolating a date from the patent sheet, you would need to base an estimate on the tube complement and the overall appearance of the unit.
: I am trying to restore a Setchell-Carlson 613B amplifier. Does anyone have a schematic or other information about this amplifier (such as when it was made, etc). All help appreciated!
11/19/2002 10:28:58 AMgeorge
:Hi,
:Have you looked at the model 13 PA Amp?
:http://ww3.nostalgiaair.org/schematics/SCI/_SCI_8-1.gif (about 1937/1938)
:If that is not the same, there may not be a schematic available.
:Sams only lists a 611, in folder 329,(which dates it to about 1956/1957) but the S.C. model Idents leave a bit to be desired.
:Short of extrapolating a date from the patent sheet, you would need to base an estimate on the tube complement and the overall appearance of the unit.
:: I am trying to restore a Setchell-Carlson 613B amplifier. Does anyone have a schematic or other information about this amplifier (such as when it was made, etc). All help appreciated!
11/19/2002 10:32:37 AMgeorge
:Hi,
: have org schematic dated 5-23-41 tubes are 1-6f5, 1-6y7, 1 6x5g, & 2-6v6g. let me know if you want copy of schematic.
