I've been reading about the slow power-up using a Variac to re-form the caps but have a question.
I plan to rent a variac but need to know the requirement specs for it.
SX-42
Power consumption - 110 Watts
Frequency - 50/60 Cycles
Line Voltage - 117 Volts
Line Current - 0.93 Amperes
I've cleaned it carfully and set all the tubes asside except the rectifier and I think I'm ready.
JH
You can use a very small variac. One rated at 3 amps will be larger than actually needed.
A 100 watt light bulb wired in series with your SX-42 will also allow power to be brought up slowly. Powering up the radio with this method will put about half the line voltage across your unit.. If there is a problem the lamp will act like a fuse and light brightly.
: I'd like to power up this unit I inherited (it hasn't been plugged in in 20+ years) and I'd like to do it correctly. I remember witnessing it in operation and am optimistic that it is intact.
: I've been reading about the slow power-up using a Variac to re-form the caps but have a question.
: I plan to rent a variac but need to know the requirement specs for it.
: SX-42
: Power consumption - 110 Watts
: Frequency - 50/60 Cycles
: Line Voltage - 117 Volts
: Line Current - 0.93 Amperes
: I've cleaned it carfully and set all the tubes asside except the rectifier and I think I'm ready.
: JH
The SX-42 had a few notorious faults that you will want to address before you leave it on for any length of time. The list is rather long, but "Phil's Old Radios" has a good rundown of what he went through on his restoration.
http://antiqueradio.org/halli07.htm
My SX-42 was in better shape than Phil's, but everything he listed as a source of a problem, was.
You can get a quick reference sheet on Phil's also, but you will likely want the whole manual. You can download the pages from here:
ftp://bama.sbc.edu/downloads/hallicra/sx42/
If you need to address the dial and gear mechanism, there is also a reference at the Bama site too.
They are a great radio.
: SX-42
: JH
