Hi Dick! Check ARRL's QST from September 1969, page 18 for a discussion of tube and solid state squelch circuits. I don't see TNS mentioned, but there is a circuit using a 12AX7. If you're a member of the ARRL you can log-on their website, do a search in the QST archives, and print a pdf copy of the article. Otherwise, there's probably a lot more in the ARRL Handbooks.
Steve
Steve
Thanks Steve. I am a member of ARRL and will check it out. Thanks again.
Dick
