Not all TV picture tubes had this coating.. Some TV's used 500mmf 20KV caps to filter high voltage. You could add a cap..
Be sure any remaining coating is grounded. There are conductive paints if you would like to repair the coating. Try Loctite Rear Window Defogger Repair Kit. (Used to repair the back window defogger in cars.)
: What material can be used to replace the aquadag coating on older tv crt's? As I understand it, the aquadag coating on the outside of the tube acts like a capacitor, providing high voltage filtering. Is it really necessary? I have a 12LP4 where the aquadag has flaked off.
Bob
: Hi
: Not all TV picture tubes had this coating.. Some TV's used 500mmf 20KV caps to filter high voltage. You could add a cap..
: Be sure any remaining coating is grounded. There are conductive paints if you would like to repair the coating. Try Loctite Rear Window Defogger Repair Kit. (Used to repair the back window defogger in cars.)
: Norm
: : What material can be used to replace the aquadag coating on older tv crt's? As I understand it, the aquadag coating on the outside of the tube acts like a capacitor, providing high voltage filtering. Is it really necessary? I have a 12LP4 where the aquadag has flaked off.
electronics shop about 8 years ago. Simply called
television tube coat. Marketed by CG Electronics
in Rockford, Illinois. part no 10-4912
Mabe the stuff can still be tracked down.
Paul
: electronics shop about 8 years ago. Simply called
: television tube coat. Marketed by CG Electronics
: in Rockford, Illinois. part no 10-4912
: Mabe the stuff can still be tracked down.
Sorry, make that GC electronics
Paul
Bob
: : I bought a spray can of the stuff at a local
: : electronics shop about 8 years ago. Simply called
: : television tube coat. Marketed by CG Electronics
: : in Rockford, Illinois. part no 10-4912
: : Mabe the stuff can still be tracked down.
: Sorry, make that GC electronics
: Paul
: Paul
