Can I replace the two R19 flexible resistors with
separate 25 ohm resistors and 2 lengths of wire?
If so what wattage would you suggest?
The wire insulation is crumbling and they measure
only about a third of the rated resistance they are
suppose to have. I have not disconnected them to measure them. I am measuring them while still connected...
Wondering why they used this type of resistor?
Bob E.
Those flexible resistors are most often OK.
If you need to replace them (which I rather doubt), you can figure the required wattage. The two R19 resistors are in series across the 6.3-V filament winding of the xfmr, so they see 3.15 V each. Power = V^2/R = 3.15^2/25 = 0.4W. Double for safety, so use 1W or higher.
Doug
:Referring to the schematic:
:http://www.nostalgiaair.org/PagesByModel/330/M0001330.pdf
:Can I replace the two R19 flexible resistors with
:separate 25 ohm resistors and 2 lengths of wire?
:If so what wattage would you suggest?
: The wire insulation is crumbling and they measure
:only about a third of the rated resistance they are
:suppose to have. I have not disconnected them to measure them. I am measuring them while still connected...
: Wondering why they used this type of resistor?
:Bob E.
:Bob: you can't measure those filament resistors while in the ckt. Study the schematic, and I think you will see why - there are various components in parallel with the resistors, including the filament winding of the xfmr. You can lift one lead and measure.
:Those flexible resistors are most often OK.
:If you need to replace them (which I rather doubt), you can figure the required wattage. The two R19 resistors are in series across the 6.3-V filament winding of the xfmr, so they see 3.15 V each. Power = V^2/R = 3.15^2/25 = 0.4W. Double for safety, so use 1W or higher.
:Doug
::Referring to the schematic:
::http://www.nostalgiaair.org/PagesByModel/330/M0001330.pdf
::Can I replace the two R19 flexible resistors with
::separate 25 ohm resistors and 2 lengths of wire?
::If so what wattage would you suggest?
:: The wire insulation is crumbling and they measure
::only about a third of the rated resistance they are
::suppose to have. I have not disconnected them to measure them. I am measuring them while still connected...
:: Wondering why they used this type of resistor?
::Bob E.
As long as the resistors aren't touching anything, the liklihood of a problem is low.
I believe those flexible resistors were wirewound. So, they should either be OK or open.
Doug
:Doug,
:Thanks,
:I thought that might be the case...but another question. These dual resistors have thick rubber
:insulation rather than cloth type. They have hardened and crumbled away in spots sometimes an inch or so in places exposing the very thin wire..What,
:if after testing them correctly and they test ok should I do to the wire/insulation. Should I just put some shrink tubing over the length of it?
:Thanks, Bob
::Bob: you can't measure those filament resistors while in the ckt. Study the schematic, and I think you will see why - there are various components in parallel with the resistors, including the filament winding of the xfmr. You can lift one lead and measure.
::Those flexible resistors are most often OK.
::If you need to replace them (which I rather doubt), you can figure the required wattage. The two R19 resistors are in series across the 6.3-V filament winding of the xfmr, so they see 3.15 V each. Power = V^2/R = 3.15^2/25 = 0.4W. Double for safety, so use 1W or higher.
::Doug
:::Referring to the schematic:
:::http://www.nostalgiaair.org/PagesByModel/330/M0001330.pdf
:::Can I replace the two R19 flexible resistors with
:::separate 25 ohm resistors and 2 lengths of wire?
:::If so what wattage would you suggest?
::: The wire insulation is crumbling and they measure
:::only about a third of the rated resistance they are
:::suppose to have. I have not disconnected them to measure them. I am measuring them while still connected...
::: Wondering why they used this type of resistor?
:::Bob E.
If I'm correct about those resistors being wirewound, shouldn't be necessary to test them - they would either work or not.
Doug
