_______________________________________________________________
R-7 will cause the described problem if it is out of value. It could be a "dog bone" resistor which looks like your description, you can use standard resistors but you may need to parallel or put them in series to get the correct value.
_____________
It's definitely not a dog bone - it's painted glass - and where the paint is chipped off, it looks like it is filled with a white paste material. Just wonder why it is constructed this way - when none of the others are.....
Best Regards,
Bill Grimm
Opps! CMF150KHFCT-ND.
Thanks Bill... I've gone through and found 3 other resistors way out of tolerance too... It shouldn't be too difficult a fix though
