You are OK if this is a power supply or audio application. If this is RF for any reason, the extra lwad inductance can work against you.
Lou
:Hi all ...I am rebuilding a Wells Gardner 2DL (Chassie 6A) and am in short supply of .05mf caps. If I take two .033 450v and put them together - to - and + to + (solder leades together to make one cap) would this be ok to substitute for a .05 cap... Voltage will stay at 450..and mf will now be .066 right?
with the tolerance of the original, the .047 is within the range
:In assume you are hooking them up in parallel. Are these ELECTROLYTIC caps (hence the +/-)?
:You are OK if this is a power supply or audio application. If this is RF for any reason, the extra lwad inductance can work against you.
:Lou
::Hi all ...I am rebuilding a Wells Gardner 2DL (Chassie 6A) and am in short supply of .05mf caps. If I take two .033 450v and put them together - to - and + to + (solder leades together to make one cap) would this be ok to substitute for a .05 cap... Voltage will stay at 450..and mf will now be .066 right?
:you could also use a .047
:with the tolerance of the original, the .047 is within the range
::In assume you are hooking them up in parallel. Are these ELECTROLYTIC caps (hence the +/-)?
::You are OK if this is a power supply or audio application. If this is RF for any reason, the extra lwad inductance can work against you.
::Lou
:::Hi all ...I am rebuilding a Wells Gardner 2DL (Chassie 6A) and am in short supply of .05mf caps. If I take two .033 450v and put them together - to - and + to + (solder leades together to make one cap) would this be ok to substitute for a .05 cap... Voltage will stay at 450..and mf will now be .066 right?
http://www.play-hookey.com/dc_theory/parallel_capacitors.html
