Need Dial Scale
10/15/2008 12:14:23 AMBrianC
While restoring a Regal brand radio, model 707, from the late 40's, I dropped and broke the dial scale. It mesures about 7" long x 1.5" high....Would appreciqte if everyone could check their bone yard for that one, even another brand would be OK if the same size.
10/15/2008 7:45:50 AMTerry F
Try Dave Frush:
www.parts2many@aol.com
Terry F
10/15/2008 8:15:32 AMA Valid Name
:... even another brand would be OK if the same size.
This might not work. Scale may be different.
10/15/2008 1:17:23 PMBill VA
What's the part number on the dial glass? I got one that size, black on copper background except black on clear for freq numbers.
Bill
:While restoring a Regal brand radio, model 707, from the late 40's, I dropped and broke the dial scale. It mesures about 7" long x 1.5" high....Would appreciqte if everyone could check their bone yard for that one, even another brand would be OK if the same size.
10/15/2008 5:07:59 PMBrianC
:What's the part number on the dial glass? I got one that size, black on copper background except black on clear for freq numbers.
:Bill
::While restoring a Regal brand radio, model 707, from the late 40's, I dropped and broke the dial scale. It mesures about 7" long x 1.5" high....Would appreciqte if everyone could check their bone yard for that one, even another brand would be OK if the same size.
HI Bill, I can't find a number on the dial glass. It is copper colored, with black numbers on clear background, measures ~7" long X 1.5" high. It says 'Electronics Regal Corporation at the bottom' of the glass. I can send a pic if you need one, but it sounds like you maybe close there. It scales from 55---165kc, there also is a strip of copper at the top.
10/15/2008 7:09:41 PMBill VA
::What's the part number on the dial glass? I got one that size, black on copper background except black on clear for freq numbers.
::Bill
:::While restoring a Regal brand radio, model 707, from the late 40's, I dropped and broke the dial scale. It mesures about 7" long x 1.5" high....Would appreciqte if everyone could check their bone yard for that one, even another brand would be OK if the same size.
:HI Bill, I can't find a number on the dial glass. It is copper colored, with black numbers on clear background, measures ~7" long X 1.5" high. It says 'Electronics Regal Corporation at the bottom' of the glass. I can send a pic if you need one, but it sounds like you maybe close there. It scales from 55---165kc, there also is a strip of copper at the top.
Here's what I have.
[IMG]http://i205.photobucket.com/albums/bb34/shedradios/DialRegal.jpg[/IMG]
Bill
10/15/2008 7:22:39 PMBill VA
:::What's the part number on the dial glass? I got one that size, black on copper background except black on clear for freq numbers.
:::Bill
::::While restoring a Regal brand radio, model 707, from the late 40's, I dropped and broke the dial scale. It mesures about 7" long x 1.5" high....Would appreciqte if everyone could check their bone yard for that one, even another brand would be OK if the same size.
::HI Bill, I can't find a number on the dial glass. It is copper colored, with black numbers on clear background, measures ~7" long X 1.5" high. It says 'Electronics Regal Corporation at the bottom' of the glass. I can send a pic if you need one, but it sounds like you maybe close there. It scales from 55---165kc, there also is a strip of copper at the top.
:Here's what I have.
:[IMG]http://i205.photobucket.com/albums/bb34/shedradios/DialRegal.jpg[/IMG]
:Bill
Just to see if anyone was paying attention. Try this.
10/16/2008 1:24:21 PMBrianC
::::What's the part number on the dial glass? I got one that size, black on copper background except black on clear for freq numbers.
::::Bill
:::::While restoring a Regal brand radio, model 707, from the late 40's, I dropped and broke the dial scale. It mesures about 7" long x 1.5" high....Would appreciqte if everyone could check their bone yard for that one, even another brand would be OK if the same size.
:::HI Bill, I can't find a number on the dial glass. It is copper colored, with black numbers on clear background, measures ~7" long X 1.5" high. It says 'Electronics Regal Corporation at the bottom' of the glass. I can send a pic if you need one, but it sounds like you maybe close there. It scales from 55---165kc, there also is a strip of copper at the top.
::Here's what I have.
::[IMG]http://i205.photobucket.com/albums/bb34/shedradios/DialRegal.jpg[/IMG]
::Bill
:Just to see if anyone was paying attention. Try this.
:Bill, That looks like the one!...I found the numbers on mine (under a copper strip someone glued on the glass), they are--25.124A...I can't quite read your numbers...dial should be about 7" X 1.5" high. If it's a match, let me know how we can work it out.
