Johnny: a radio will pull the most amperage at turn-on as the filaments heat up. A fast-blo fuse usually opens up under such conditions. A slo-blow fuse is what you want. Adding a CL-90 thermister also controls the inrush current since it has high resistance till it warms up and passes current and avoids a lot of stress on those valuable tubes.
Steve
Steve:
In general, use fast blow on transistor circuits, slo blow on tubes.
Steve:
I was trying to say that tubes can stand a surge that will not blow a slo-blow fuse that would zap a transistor. And yes, the input surge of current going into a cold filament string could easily blow a fast blow fuse when there is no problem with the radio.
::Lewis
Steve, difference in slo blow and fast (actual regular)fuse is that slo blow designed to take an istantaneous overload momentarily without blowing whereas regular fuse blows as soon as ampereage exceeded. PL
