Atwater Kent 317 Rectifier Tube Next burning question...
10/9/2008 9:19:32 PMBob E.
Wondering about Rectifiers
Schematic Calls for a 5Z4
Chassis has stamped base 5Y4G
My tube book says sub for 5Z4
is either 5Y3 or 5Y4
Are all three of these interchangeable with no modifications? Any of the 3 better than the others?
I have lots of 5Y3's on hand and only one other
5Z4 that I would like to use in another set coming up.
Any vewy sage advice for me?
Bob E.
10/9/2008 9:50:24 PMBob E Minor Correction
Chassis is NOT stamped 5Y4 but question still
remains as asked for substitution...
I was looking at a Zenith Chassis that I will be
getting to next. I heard today you were not suppose to
double-task like that because it is easy to get confused... guess they're right.. :O)
:Wondering about Rectifiers
:Schematic Calls for a 5Z4
:Chassis has stamped base 5Y4G
:My tube book says sub for 5Z4
: is either 5Y3 or 5Y4
:Are all three of these interchangeable with no modifications? Any of the 3 better than the others?
:I have lots of 5Y3's on hand and only one other
:5Z4 that I would like to use in another set coming up.
:Any vewy sage advice for me?
:Bob E.
10/9/2008 10:30:41 PMplanigan
:Chassis is NOT stamped 5Y4 but question still
:remains as asked for substitution...
:I was looking at a Zenith Chassis that I will be
:getting to next. I heard today you were not suppose to
:double-task like that because it is easy to get confused... guess they're right.. :O)
:Bob 5Z4 and 5Y3 have same pinout and are 350V max at 125 ma. 5Y4 has differant pinout but same ratings. Plates on 5Y4 3 & 5, Htr/C 7-8. PL
::Wondering about Rectifiers
::Schematic Calls for a 5Z4
::Chassis has stamped base 5Y4G
::My tube book says sub for 5Z4
:: is either 5Y3 or 5Y4
::Are all three of these interchangeable with no modifications? Any of the 3 better than the others?
::I have lots of 5Y3's on hand and only one other
::5Z4 that I would like to use in another set coming up.
::Any vewy sage advice for me?
::Bob E.
10/10/2008 12:08:04 AMBob E.
So the 5Z4 and 5Y3 have same pinout and are 350V max at 125 ma....so this DOES mean they are directly
substitutable with each other?
Thanks, Bob
10/10/2008 5:23:41 PMRighto . . . .on the 5Z4-5Y3 sub..E
:So the 5Z4 and 5Y3 have same pinout and are 350V max at 125 ma....so this DOES mean they are directly
:substitutable with each other?
:Thanks, Bob
