PERFECT ANTENNA!!!!!!!!!!
10/9/2008 3:02:48 AMG.Berg
Do you need a antenna for your old radio and do not want to run a long wire ??? I have tried this and it works GREAT!!!!! If you have a forced air heating/cooling system in your house use the duct work as an antenna. Simply connect antenna wire from radio to heat/cool register and WOOLA....instant antenna!!!! The duct work that runs though out the house works as a massive antenna!!!!
10/9/2008 4:13:25 AMLou
Well, this is a neat idea, BUT
I would be very careful since the ductwork is actually grounded.
Some old radios may have a path to B plus or the line somewhere in the input.In that case, you could hurt yourself, cause a fire or what have you.
Before connecting to ductwork,you should check the input circuit of your radio.
Lou
:Do you need a antenna for your old radio and do not want to run a long wire ??? I have tried this and it works GREAT!!!!! If you have a forced air heating/cooling system in your house use the duct work as an antenna. Simply connect antenna wire from radio to heat/cool register and WOOLA....instant antenna!!!! The duct work that runs though out the house works as a massive antenna!!!!
10/9/2008 11:22:12 AMBZZZZZZZTTTT!!!!!!
That sounds like a shocking concept
:Well, this is a neat idea, BUT
:I would be very careful since the ductwork is actually grounded.
:Some old radios may have a path to B plus or the line somewhere in the input.In that case, you could hurt yourself, cause a fire or what have you.
:Before connecting to ductwork,you should check the input circuit of your radio.
:Thanks
:Lou
::Do you need a antenna for your old radio and do not want to run a long wire ??? I have tried this and it works GREAT!!!!! If you have a forced air heating/cooling system in your house use the duct work as an antenna. Simply connect antenna wire from radio to heat/cool register and WOOLA....instant antenna!!!! The duct work that runs though out the house works as a massive antenna!!!!
10/9/2008 1:04:40 PMjayw
Also, modern ductwork is non-metalic
Jim
:That sounds like a shocking concept
::Well, this is a neat idea, BUT
::I would be very careful since the ductwork is actually grounded.
::Some old radios may have a path to B plus or the line somewhere in the input.In that case, you could hurt yourself, cause a fire or what have you.
::Before connecting to ductwork,you should check the input circuit of your radio.
::Thanks
::Lou
:::Do you need a antenna for your old radio and do not want to run a long wire ??? I have tried this and it works GREAT!!!!! If you have a forced air heating/cooling system in your house use the duct work as an antenna. Simply connect antenna wire from radio to heat/cool register and WOOLA....instant antenna!!!! The duct work that runs though out the house works as a massive antenna!!!!
10/9/2008 4:05:36 PMgreg
Be sure to have all your ducts in a row before connecting the antenna to the HVAC system
:Also, modern ductwork is non-metalic
:Jim
::That sounds like a shocking concept
:::Well, this is a neat idea, BUT
:::I would be very careful since the ductwork is actually grounded.
:::Some old radios may have a path to B plus or the line somewhere in the input.In that case, you could hurt yourself, cause a fire or what have you.
:::Before connecting to ductwork,you should check the input circuit of your radio.
:::Thanks
:::Lou
::::Do you need a antenna for your old radio and do not want to run a long wire ??? I have tried this and it works GREAT!!!!! If you have a forced air heating/cooling system in your house use the duct work as an antenna. Simply connect antenna wire from radio to heat/cool register and WOOLA....instant antenna!!!! The duct work that runs though out the house works as a massive antenna!!!!
10/9/2008 7:05:50 PMPacha 73
:Be sure to have all your ducts in a row before connecting the antenna to the HVAC system
::Also, modern ductwork is non-metalic
::Jim
:::That sounds like a shocking concept
::::Well, this is a neat idea, BUT
::::I would be very careful since the ductwork is actually grounded.
::::Some old radios may have a path to B plus or the line somewhere in the input.In that case, you could hurt yourself, cause a fire or what have you.
::::Before connecting to ductwork,you should check the input circuit of your radio.
::::Thanks
::::Lou
:::::Do you need a antenna for your old radio and do not want to run a long wire ??? I have tried this and it works GREAT!!!!! If you have a forced air heating/cooling system in your house use the duct work as an antenna. Simply connect antenna wire from radio to heat/cool register and WOOLA....instant antenna!!!! The duct work that runs though out the house works as a massive antenna!!!!
10/9/2008 7:11:02 PMPacha 73
:Also, modern ductwork is non-metalic Where do you live that the ductwork is not made of sheet metal? I have been a sheetmetal worker over 40 years and here it is still metal. Pacha73 in Canada
:Jim
:::Thanks
:::Lou
10/9/2008 7:35:22 PMMike C
Ductwork in the states varies from ductboard to sheet metal according to how much you want to pay or how much the contractor is willing to spend on a condo, an apartment,condo,or subdivision. Metal duct should have a canvas connection at the air handler and ductboard is fiberglass with an aluminum outer cover. Still,that doesn't mean I'd use it as an antenna???
::Jim
::::Thanks
::::Lou
10/9/2008 8:59:44 PMCharlie
Here in Texas the newer flex-duct has been the most common in recent years, the better stuff has an outside foil wrap though.
:Ductwork in the states varies from ductboard to sheet metal according to how much you want to pay or how much the contractor is willing to spend on a condo, an apartment,condo,or subdivision. Metal duct should have a canvas connection at the air handler and ductboard is fiberglass with an aluminum outer cover. Still,that doesn't mean I'd use it as an antenna???
:modern ductwork is non-metalic Where do you live that the ductwork is not made of sheet metal? I have been a sheetmetal worker over 40 years and here it is still metal. Pacha73 in Canada
:::Jim
::::That sounds like a shocking concept
:::::Well, this is a neat idea, BUT
:::::I would be very careful since the ductwork is actually grounded.
:::::Some old radios may have a path to B plus or the line somewhere in the input.In that case, you could hurt yourself, cause a fire or what have you.
:::::Before connecting to ductwork,you should check the input circuit of your radio.
:::::Thanks
:::::Lou
::::::Do you need a antenna for your old radio and do not want to run a long wire ??? I have tried this and it works GREAT!!!!! If you have a forced air heating/cooling system in your house use the duct work as an antenna. Simply connect antenna wire from radio to heat/cool register and WOOLA....instant antenna!!!! The duct work that runs though out the house works as a massive antenna!!!!
10/10/2008 10:29:43 AMjayw
My reference was to flexable insulated ducts. The ones in my attic have a plastic core covered by an insulation blanket. That is what I see sold in the 'big box' stores as well.
Jim
:Here in Texas the newer flex-duct has been the most common in recent years, the better stuff has an outside foil wrap though.
::Ductwork in the states varies from ductboard to sheet metal according to how much you want to pay or how much the contractor is willing to spend on a condo, an apartment,condo,or subdivision. Metal duct should have a canvas connection at the air handler and ductboard is fiberglass with an aluminum outer cover. Still,that doesn't mean I'd use it as an antenna???
::modern ductwork is non-metalic Where do you live that the ductwork is not made of sheet metal? I have been a sheetmetal worker over 40 years and here it is still metal. Pacha73 in Canada
::::Jim
:::::That sounds like a shocking concept
::::::Well, this is a neat idea, BUT
::::::I would be very careful since the ductwork is actually grounded.
::::::Some old radios may have a path to B plus or the line somewhere in the input.In that case, you could hurt yourself, cause a fire or what have you.
::::::Before connecting to ductwork,you should check the input circuit of your radio.
::::::Thanks
::::::Lou
:::::::Do you need a antenna for your old radio and do not want to run a long wire ??? I have tried this and it works GREAT!!!!! If you have a forced air heating/cooling system in your house use the duct work as an antenna. Simply connect antenna wire from radio to heat/cool register and WOOLA....instant antenna!!!! The duct work that runs though out the house works as a massive antenna!!!!
10/11/2008 8:29:43 AMCharlie
When they started using flex-duct here it was the standard one with a inner plastic core, insulation and an outer plastic covering. I think the UV rays were breaking down the outer plastic and we had to start using the heavier outer foil covered type.
:My reference was to flexable insulated ducts. The ones in my attic have a plastic core covered by an insulation blanket. That is what I see sold in the 'big box' stores as well.
:Jim
::Here in Texas the newer flex-duct has been the most common in recent years, the better stuff has an outside foil wrap though.
:::Ductwork in the states varies from ductboard to sheet metal according to how much you want to pay or how much the contractor is willing to spend on a condo, an apartment,condo,or subdivision. Metal duct should have a canvas connection at the air handler and ductboard is fiberglass with an aluminum outer cover. Still,that doesn't mean I'd use it as an antenna???
:::modern ductwork is non-metalic Where do you live that the ductwork is not made of sheet metal? I have been a sheetmetal worker over 40 years and here it is still metal. Pacha73 in Canada
:::::Jim
::::::That sounds like a shocking concept
:::::::Well, this is a neat idea, BUT
:::::::I would be very careful since the ductwork is actually grounded.
:::::::Some old radios may have a path to B plus or the line somewhere in the input.In that case, you could hurt yourself, cause a fire or what have you.
:::::::Before connecting to ductwork,you should check the input circuit of your radio.
:::::::Thanks
:::::::Lou
::::::::Do you need a antenna for your old radio and do not want to run a long wire ??? I have tried this and it works GREAT!!!!! If you have a forced air heating/cooling system in your house use the duct work as an antenna. Simply connect antenna wire from radio to heat/cool register and WOOLA....instant antenna!!!! The duct work that runs though out the house works as a massive antenna!!!!
