Foreign Radio tube layout
10/7/2008 12:20:10 PMNeal Buddenberg
I know you do not do German Radios, but my problem is simple: The physical tube complement of my EMUD Rekord Junior 196 does not match the layout chart on the radio back cover, and one socket is empty (tube missing). I am sure the set has not been rewired. Any suggestions? Thanks....
10/7/2008 12:43:41 PMCarl T
:I know you do not do German Radios, but my problem is simple: The physical tube complement of my EMUD Rekord Junior 196 does not match the layout chart on the radio back cover, and one socket is empty (tube missing). I am sure the set has not been rewired. Any suggestions? Thanks....
Neal,
The empty socket is a test socket.
What variation do you see with the tube lay-out?
Carl T
10/8/2008 6:38:51 PMNeal Buddenberg
::I know you do not do German Radios, but my problem is simple: The physical tube complement of my EMUD Rekord Junior 196 does not match the layout chart on the radio back cover, and one socket is empty (tube missing). I am sure the set has not been rewired. Any suggestions? Thanks....
:Neal,
:The empty socket is a test socket.
:What variation do you see with the tube lay-out?
:Carl T
10/8/2008 6:45:35 PMNeal Buddenberg
:Neal,
:Carl T
Carl, the confusing thing about the tube layout diagram is that it tries to suggest the position of one the tubes is in the test socket. Once you told me that it wasn't a tube socket, it made more sense. One other thing, though, the FM section is kind of weak. Tubes are good, replaced a few bad caps, AM is strong. Any thoughts? Thanks again.....
10/9/2008 8:22:07 AMCarl T
:::I know you do not do German Radios, but my problem is simple: The physical tube complement of my EMUD Rekord Junior 196 does not match the layout chart on the radio back cover, and one socket is empty (tube missing). I am sure the set has not been rewired. Any suggestions? Thanks....
::Neal,
::The empty socket is a test socket.
::What variation do you see with the tube lay-out?
::Carl T
:Carl, the confusing thing about the tube layout diagram is that it tries to suggest the position of one the tubes is in the test socket. Once you told me that it wasn't a tube socket, it made more sense. One other thing, though, the FM section is kind of weak. Tubes are good, replaced a few bad caps, AM is strong. Any thoughts? Thanks again.....
Neal,
I've emailed a copy of the service lit to you.
I don't have a lot of experience with FM sets.
Dirty band switch?
Carl T
