Marconi Model 187 Volume Problem
10/6/2008 7:53:49 PMGary W. Prutchick
OK here's what I know:
I am near the finish line on the restoration of this Marconi Model 187.
Replaced all caps, some resistors, cleaned the switch assembly, cleaned the tuning capacitor, replaced the speaker with a PM type, installed a choke and a resistor to replace the field coil, rejuvenated the bias cell, replaced the volume control, did an alignment on all 5 bands and set the pre-set stations.
The radio works great with one exception:
On very strong stations there is little to no control of the volume. It seems that it is either too loud or not loud enough.
Here's what I don't know,
Could this be an AVC issue?
Or is this an audio taper vs linear taper issue?
I'm not sure, but I think the replacement volume control was an audio taper.
I have double checked the bias cell and it is still measuring 1.2 volts.
Thoughts anyone?
Gary
10/11/2008 11:53:59 AMNorm Leal
Hi Gary
If the control is adjusting input to 1st audio amplifier grid it's usually 500K or 1 meg, audio taper.
AVC reduces signal strength on strong stations but your volume control should still give proper adjustment. It should not jump from too low to too high. This indicates a bad spot in carbon element of the control.
:OK here's what I know:
:I am near the finish line on the restoration of this Marconi Model 187.
:Replaced all caps, some resistors, cleaned the switch assembly, cleaned the tuning capacitor, replaced the speaker with a PM type, installed a choke and a resistor to replace the field coil, rejuvenated the bias cell, replaced the volume control, did an alignment on all 5 bands and set the pre-set stations.
:The radio works great with one exception:
:On very strong stations there is little to no control of the volume. It seems that it is either too loud or not loud enough.
:Here's what I don't know,
:Could this be an AVC issue?
:Or is this an audio taper vs linear taper issue?
:I'm not sure, but I think the replacement volume control was an audio taper.
:I have double checked the bias cell and it is still measuring 1.2 volts.
:Thoughts anyone?
:Gary
