Parasitic-Oscillation
10/3/2008 11:09:48 AMBob Z
I have a amplifier using 6L6's in push pull. I am getting a little parasitic oscillation when i run a 400 Hz sine wave at full power. I remember from years ago putting a serial resistor in the plate circuit, between the plate and output transformer lead to suppress the oscillation.
Relocating the coupling caps has it almost gone, but I think adding the plate resistor's would be a good idea.
Anybody remember the normal value used ???
Thanks Bob
10/3/2008 11:51:18 AMMike M.
Bob,
Look at this site. http://www.montagar.com/~PATJ/ap56.htm
They used 50 ohm 1W.
Mike M.
:I have a amplifier using 6L6's in push pull. I am getting a little parasitic oscillation when i run a 400 Hz sine wave at full power. I remember from years ago putting a serial resistor in the plate circuit, between the plate and output transformer lead to suppress the oscillation.
:Relocating the coupling caps has it almost gone, but I think adding the plate resistor's would be a good idea.
:Anybody remember the normal value used ???
:Thanks Bob
10/3/2008 12:08:57 PMBob Z
Thanks Mike,
That amp looks quite nice, although a little over kill with the seperate bias for each of the 4 output tubes. But it answered my question.
:Bob,
:Look at this site. http://www.montagar.com/~PATJ/ap56.htm
:They used 50 ohm 1W.
:Mike M.
::I have a amplifier using 6L6's in push pull. I am getting a little parasitic oscillation when i run a 400 Hz sine wave at full power. I remember from years ago putting a serial resistor in the plate circuit, between the plate and output transformer lead to suppress the oscillation.
::Relocating the coupling caps has it almost gone, but I think adding the plate resistor's would be a good idea.
::Anybody remember the normal value used ???
::Thanks Bob
