missing power transformer
10/1/2008 11:22:05 PMChuck
I am in the middle of restoring a crosley 82cp chassis 75. In Riders, its Crosley page 13-33. The problem is the power transformer is missing and I would like to get a replacement to finish the project. It looks like the transformer lays on its side in the chasis. Someone wrote 300-300 5v 6.3v on a piece of paper. The schematic shows yellow-yellow, red-yellow-red-red, green-green. What do the colors mean on voltages? And last, where can I get a replacement transformer? Thanks again for your help!
Chuck
10/2/2008 12:30:19 AMplanigan
:I am in the middle of restoring a crosley 82cp chassis 75. In Riders, its Crosley page 13-33. The problem is the power transformer is missing and I would like to get a replacement to finish the project. It looks like the transformer lays on its side in the chasis. Someone wrote 300-300 5v 6.3v on a piece of paper. The schematic shows yellow-yellow, red-yellow-red-red, green-green. What do the colors mean on voltages? And last, where can I get a replacement transformer? Thanks again for your help!
:Chuck
Chuck, go to Resources-Color Codes-Power Xfmer on this site for color coding info on xfmr. PL
10/2/2008 6:46:32 AMTonyJ
Radio Daze sells a line of Hammond transformers and should have a unit with the voltages you need. Physical sizes should be listed on their site also just to make sure the replacement is going to fit. Hope that helps.
http://www.radiodaze.com/
::I am in the middle of restoring a crosley 82cp chassis 75. In Riders, its Crosley page 13-33. The problem is the power transformer is missing and I would like to get a replacement to finish the project. It looks like the transformer lays on its side in the chasis. Someone wrote 300-300 5v 6.3v on a piece of paper. The schematic shows yellow-yellow, red-yellow-red-red, green-green. What do the colors mean on voltages? And last, where can I get a replacement transformer? Thanks again for your help!
::Chuck
:Chuck, go to Resources-Color Codes-Power Xfmer on this site for color coding info on xfmr. PL
10/2/2008 12:30:02 PMRene van Gaalen
Since your original transformer is missing the wiring color info on the schematic may not mean a whole lot unless your replacement transformer uses the same color coding. When you go searching for a replacement, you will need to know the current requirements for the HV/B+ side as well as the filament windings.
:Chuck
