Thanks for your help.
Check it out……!. . . . . . . . . .(Is about 1/3 way down, in the total summation )
Right ‘chere. . . . . . . . . ( xXx )
: Check it out……!. . . . . . . . . .(Is about 1/3 way down, in the total summation )
:Right ‘chere. . . . . . . . . ( xXx )
So, if I understand it correctly, the D-20 Power Cabinet we have should be matched up with a Hammond Organ, Model D? or D-20? We have a small organ, but I don't know if it is a Hammond or not. The reference says the D-20 is the same as the C-20, but with a more utilitarian cabinet. The C-20 only has 20 watt output, but the tag on our D-20 power cabinet says 177 watts. BTW, the SN is 5779 if anyone has references to those numbers.
:Thanks
:: Check it out……!. . . . . . . . . .(Is about 1/3 way down, in the total summation )
::Right ‘chere. . . . . . . . . ( xXx )
::73's de Edd
Edd and all:
Wouldn't you think 177 Watts is the AC input power?
Why . . .soitanly. . .the units AC power input. . . .but for it to solely be used in acquiring that 20W RMS of the power amp in
the unit, . . . . .I would equate that to an automobile getting 5 MPG.
(Awright now. . .for sure, someone's going to come back with….I USED TO OWN ONE OF THOSE ! )
As I recall, that is about the gas milage a class "A" amplifier got. ~{;o)
