ZENITH 10S464
9/29/2008 12:25:41 PMG.Berg
Hi all...I have a zenith model 10S464 that has a slight problem that I am confused bout... On the "Wavemagnet" antenna is a switch for local and distant reception...When I flip switch to local it gets loud (as it should) then fades /cuts out almost completely a few seconds later..I thought it was a problem with switch but it checks out good....Any suggestions? Bad tube, resistor??
9/30/2008 10:14:47 PMSteve - W9DX
:Hi all...I have a zenith model 10S464 that has a slight problem that I am confused bout... On the "Wavemagnet" antenna is a switch for local and distant reception...When I flip switch to local it gets loud (as it should) then fades /cuts out almost completely a few seconds later..I thought it was a problem with switch but it checks out good....Any suggestions? Bad tube, resistor??
Check resistors R1 and R2 for proper values and check for shorts. The local/distant switch merely adds in a parallel resistor when closed. Have you replaced caps C2 and C3?
Steve
10/1/2008 1:20:48 PMG. Berg
Ok thanks will try that::
:Check resistors R1 and R2 for proper values and check for shorts. The local/distant switch merely adds in a parallel resistor when closed. Have you replaced caps C2 and C3?
:Steve
