stromberg-carlson radio model-674 serial-6742825
9/28/2008 7:13:47 PMstan
I was woundering if anybody would know or might have information on the above radio, it came from the dump, it was part of an console radio-phono combo.,but the receaver was the only thing in one piece, no speaker either, the tubes where still in the set, as follows,-6f6x2-6sq7x2-6sa7-6sk7-5y4-, it has x4-bands by the look of the windsheild, bc-19m-25m-31m, although?, the band rotoryswitch has five positions avaliable,there is no back for the radio, and no info from it, although I might think the seven-pin-connector on the back of the chassis is for the speaker-transformer, I,d really not like too take any chances and short everything too bits, if anybody outthere might have some information about this radio set, I would be really greatful, you see, if I can get this set working, I'm going too build an wooden case for it and the speaker, thankyous verymuch.
stan
9/29/2008 4:59:47 AMGary W. Prutchcik
Stan,
I've emailed the schematic and alignment instructions.
Gary
:I was woundering if anybody would know or might have information on the above radio, it came from the dump, it was part of an console radio-phono combo.,but the receaver was the only thing in one piece, no speaker either, the tubes where still in the set, as follows,-6f6x2-6sq7x2-6sa7-6sk7-5y4-, it has x4-bands by the look of the windsheild, bc-19m-25m-31m, although?, the band rotoryswitch has five positions avaliable,there is no back for the radio, and no info from it, although I might think the seven-pin-connector on the back of the chassis is for the speaker-transformer, I,d really not like too take any chances and short everything too bits, if anybody outthere might have some information about this radio set, I would be really greatful, you see, if I can get this set working, I'm going too build an wooden case for it and the speaker, thankyous verymuch.
: stan
9/30/2008 4:14:10 AMstan
: stan . hi Gary, I'd like to say thankyou for your responce too my request, if it is possible, could you resend the information about the stronberg-carlson radio again, I've had some problems with my computor & my email server, if you could do this I'd be most grearful, thankyou.
stan gbates6@cogeco.ca
9/30/2008 4:47:15 AMGary W. Prutchick
Hi Stan,
Info has been sent.
Gary
::I was woundering if anybody would know or might have information on the above radio, it came from the dump, it was part of an console radio-phono combo.,but the receaver was the only thing in one piece, no speaker either, the tubes where still in the set, as follows,-6f6x2-6sq7x2-6sa7-6sk7-5y4-, it has x4-bands by the look of the windsheild, bc-19m-25m-31m, although?, the band rotoryswitch has five positions avaliable,there is no back for the radio, and no info from it, although I might think the seven-pin-connector on the back of the chassis is for the speaker-transformer, I,d really not like too take any chances and short everything too bits, if anybody outthere might have some information about this radio set, I would be really greatful, you see, if I can get this set working, I'm going too build an wooden case for it and the speaker, thankyous verymuch.
:: stan . hi Gary, I'd like to say thankyou for your responce too my request, if it is possible, could you resend the information about the stronberg-carlson radio again, I've had some problems with my computor & my email server, if you could do this I'd be most grearful, thankyou.
: stan gbates6@cogeco.ca
9/30/2008 7:57:20 PMstan
:Hi Stan,
:Info has been sent.
:Gary
:::I was woundering if anybody would know or might have information on the above radio, it came from the dump, it was part of an console radio-phono combo.,but the receaver was the only thing in one piece, no speaker either, the tubes where still in the set, as follows,-6f6x2-6sq7x2-6sa7-6sk7-5y4-, it has x4-bands by the look of the windsheild, bc-19m-25m-31m, although?, the band rotoryswitch has five positions avaliable,there is no back for the radio, and no info from it, although I might think the seven-pin-connector on the back of the chassis is for the speaker-transformer, I,d really not like too take any chances and short everything too bits, if anybody outthere might have some information about this radio set, I would be really greatful, you see, if I can get this set working, I'm going too build an wooden case for it and the speaker, thankyous verymuch.
::: stan . hi Gary, I'd like to say thankyou for your responce too my request, if it is possible, could you resend the information about the stronberg-carlson radio again, I've had some problems with my computor & my email server, if you could do this I'd be most grearful, thankyou.
:: stan gbates6@cogeco.ca stan, hi again Gary,thanyou again for emailing me, I did receive the infomation for the web-site too go to, I could not download the file, something I think might very well with my computor,I could open all my other emails, I really hate too be that thorn in you side, but is there any way I could download this informatio from this site ? thankyou again Gary.
10/1/2008 3:45:10 PMEdd
It sounds like you have got yourself something that will really drive speaker for you along with the receiver circuitry being
adequate, only lacking an RF stage and an eye tube in order to fully gild the lilly.
Heck, you might even be able to listen to some shortly wavelets.
What with your description of difficulties in opening a file. . . .I wonder what the possibilities are of your having encountered
Deja vu. . . and your then having been thoroughly DEJ-uh-vuuuued !
Certainly hope that you never run up against
an extreme high density multi part RAR file .
I'll just reformat and put that sets most relevant info up here and additionally touch on some markups of the speaker type
that you were left without and its hook up info.
I see that this chassis coverage does not seem to be on site, so others SAVE, if of possible interest in the future.
Slight schematic anomaly:
The conventional ohms sign on this print is meant to be read out as a megohm symbol, while the ohms symbol is akin to its
appearing as a cursive small w symbolization. For further clarification as well as familiarization, check out the 1st grid
and plate / screen resistors of the audio stages for the Megohm usage; then take a look over to the cathode resistor values
for the Ohms usage.
SCHEMATIC. . . PLUS:
10/1/2008 6:17:27 PMGary W. Prutchick
Hi Stan,
The file attachment is a pdf file.
Do you have the Adobe Reader? This reader is free to download from Adobe.
Gary
::Hi Stan,
::Info has been sent.
::Gary
::::I was woundering if anybody would know or might have information on the above radio, it came from the dump, it was part of an console radio-phono combo.,but the receaver was the only thing in one piece, no speaker either, the tubes where still in the set, as follows,-6f6x2-6sq7x2-6sa7-6sk7-5y4-, it has x4-bands by the look of the windsheild, bc-19m-25m-31m, although?, the band rotoryswitch has five positions avaliable,there is no back for the radio, and no info from it, although I might think the seven-pin-connector on the back of the chassis is for the speaker-transformer, I,d really not like too take any chances and short everything too bits, if anybody outthere might have some information about this radio set, I would be really greatful, you see, if I can get this set working, I'm going too build an wooden case for it and the speaker, thankyous verymuch.
:::: stan . hi Gary, I'd like to say thankyou for your responce too my request, if it is possible, could you resend the information about the stronberg-carlson radio again, I've had some problems with my computor & my email server, if you could do this I'd be most grearful, thankyou.
::: stan gbates6@cogeco.ca stan, hi again Gary,thanyou again for emailing me, I did receive the infomation for the web-site too go to, I could not download the file, something I think might very well with my computor,I could open all my other emails, I really hate too be that thorn in you side, but is there any way I could download this informatio from this site ? thankyou again Gary.
10/1/2008 7:36:41 PMstan
: stan
goodevening Gary, thanx for the whole ball of wax, I think my problem with this putor, might have been adobe pdf program, I typed it in on google, and went too the site and downloaded the program, I then went back too email and clicked on the file you had emailed me, I got rederected and what do you know?, the file was opened on the putor, this was just great, but then my printer went on the frix, so then I saved the program too floppy, this was so great, thankyou sooooooooooo! much Gary, I thought maybe we much keep-in-touch, contact here & there.
thanx-again Gary.
