Thanks to all.
Bob
:Hit enter by mistake, I just received a Masco 27 watt pa amplifier from the early 60's. Model Audiosphere 27. It was used in a skating rink that closed in the late 60's. The unit has been hacked up a bit, tubes and transformers are present but some of the resistor's/capacitors are missing. You can see where they were cut out from.
: It looks like a straight forward push pull set up, but having the schmatic would be nice. Tube complement is (2) 6L6, 5v4 (5u4 now in unit), (2) 12ax7 and a 6ba6.
: If anyone has a diagram or knows where i can download from I would appreciate it.
:Thanks to all.
:Bob
:Bob Z, Schematic sent.
:Bill
::Hit enter by mistake, I just received a Masco 27 watt pa amplifier from the early 60's. Model Audiosphere 27. It was used in a skating rink that closed in the late 60's. The unit has been hacked up a bit, tubes and transformers are present but some of the resistor's/capacitors are missing. You can see where they were cut out from.
:: It looks like a straight forward push pull set up, but having the schmatic would be nice. Tube complement is (2) 6L6, 5v4 (5u4 now in unit), (2) 12ax7 and a 6ba6.
:: If anyone has a diagram or knows where i can download from I would appreciate it.
::Thanks to all.
::Bob
:Bill
::Thanks to all.
::Bob
Daniel, schematic sent.
Bill
:Hi, I have an Audiosphere 27 with a large green dogbone burned up resistor, with the identifying marks scorched off of course. I'd dearly love to have a copy of the schmematic to see if I can identify the resistor. Could you possibly send a copy to my email? the7swede@sbcglobal.net thanks....
::Bob Z, Schematic sent.
::Bill
:::Hit enter by mistake, I just received a Masco 27 watt pa amplifier from the early 60's. Model Audiosphere 27. It was used in a skating rink that closed in the late 60's. The unit has been hacked up a bit, tubes and transformers are present but some of the resistor's/capacitors are missing. You can see where they were cut out from.
::: It looks like a straight forward push pull set up, but having the schmatic would be nice. Tube complement is (2) 6L6, 5v4 (5u4 now in unit), (2) 12ax7 and a 6ba6.
::: If anyone has a diagram or knows where i can download from I would appreciate it.
:::Thanks to all.
:::Bob
