:Greetings,
:Is it true if a cap has polarity before and after the tube that it is leaky and no good? I have one in a radio that is such and the others do not test that way.
:Thank you,
:Vinny
:I'm confused here. What do you mean by "polarity before and after the tube"?
:Doug
"polarity before and after the cap"????? I don't understand what that means at all!
::Doug, Before and after the cap, sorry.
:What the heck does THAT mean?
:"polarity before and after the cap"????? I don't understand what that means at all!
"Polarity" applies to electrolytic caps. There is an anode (+) and cathode (-): they are built into the cap at the cap factory and are marked on the cap itself.
Doug
:Must be new, NEW math or maybe new, NEW economics, but don't ask Wall St, they're still confused.
:marv
:::Doug, Before and after the cap, sorry.
::What the heck does THAT mean?
::"polarity before and after the cap"????? I don't understand what that means at all!
:Vinny, the terminology is confusing us. Are you measuring voltages, possibly residual voltages after the radio's power is turned off? If so, where? (I'm grasping at straws here to try to understand your concern.)
:"Polarity" applies to electrolytic caps. There is an anode (+) and cathode (-): they are built into the cap at the cap factory and are marked on the cap itself.
:Doug
::Must be new, NEW math or maybe new, NEW economics, but don't ask Wall St, they're still confused.
::marv
::::Doug, Before and after the cap, sorry.
:::What the heck does THAT mean?
:::"polarity before and after the cap"????? I don't understand what that means at all!
:Doug
::marv
:Sorry, the word is continuity not polarized--lack of sleep.
:Vinny
::Vinny, the terminology is confusing us. Are you measuring voltages, possibly residual voltages after the radio's power is turned off? If so, where? (I'm grasping at straws here to try to understand your concern.)
::"Polarity" applies to electrolytic caps. There is an anode (+) and cathode (-): they are built into the cap at the cap factory and are marked on the cap itself.
::Doug
:Small value film caps should measure infinite resistance with an ohmmeter. But you have to lift one lead of the cap to get a valid measurement (unless, by inspection of the schematic, there is no component in parallel with the cap what would throw off the resistance measurement).
:Doug
::Sorry, the word is continuity not polarized--lack of sleep.
::Vinny
:::Vinny, the terminology is confusing us. Are you measuring voltages, possibly residual voltages after the radio's power is turned off? If so, where? (I'm grasping at straws here to try to understand your concern.)
:::"Polarity" applies to electrolytic caps. There is an anode (+) and cathode (-): they are built into the cap at the cap factory and are marked on the cap itself.
:::Doug
Are you referring to a coupling capacitor between two tube stages, plate of preceding tube to the grid of the next tube, having positive voltage on both sides of the capacitor?
::I'm confused here. What do you mean by "polarity before and after the tube"?
::Doug
