Ducretet-thomson
9/16/2008 2:23:46 PMVinny
I was given a french radio, would it play in the US and receive the regular radio stations?
Also I took it apart to see how to change the caps, they were rated in PF and appeared to be tubular plastic which seem to crack easy.
I saw a couple of caps that read:
25,000 PF
500 / 15,000 volts
Is that an unusual amount of voltage, can that be real, which is it, 500volts or 15, 000volts? can these type of caps be bought?
Thank you,
Vinny
9/16/2008 4:56:35 PMDoug Criner
Vinny: it will probably receive the AM broadcast band. Does the tuning dial show the covered frequencies?
If it's an AC set, it will probably be designed for 220V.
A single cap should have just one voltage rating. 15kV wouldn't make sense to me.
1 pF = 1 uuF = (10^-6) uF
Doug
:I was given a french radio, would it play in the US and receive the regular radio stations?
:Also I took it apart to see how to change the caps, they were rated in PF and appeared to be tubular plastic which seem to crack easy.
:I saw a couple of caps that read:
:25,000 PF
:500 / 15,000 volts
:Is that an unusual amount of voltage, can that be real, which is it, 500volts or 15, 000volts? can these type of caps be bought?
:Thank you,
:Vinny
9/16/2008 6:50:40 PMVinny
Doug, When I did research it read 110Volts.
thank You,
Vinny
:Vinny: it will probably receive the AM broadcast band. Does the tuning dial show the covered frequencies?
:If it's an AC set, it will probably be designed for 220V.
:A single cap should have just one voltage rating. 15kV wouldn't make sense to me.
:1 pF = 1 uuF = (10^-6) uF
:Doug
::I was given a french radio, would it play in the US and receive the regular radio stations?
::Also I took it apart to see how to change the caps, they were rated in PF and appeared to be tubular plastic which seem to crack easy.
::I saw a couple of caps that read:
::25,000 PF
::500 / 15,000 volts
::Is that an unusual amount of voltage, can that be real, which is it, 500volts or 15, 000volts? can these type of caps be bought?
::Thank you,
::Vinny
9/16/2008 7:40:11 PMDoug Criner
Vinny: OK, whatever. The standard AC voltage in Europe is, now at least, 220V. Some radios manufactured in Europe, for sale in North America, had a switch to select between 120- and 220-V.
Doug
:Doug, When I did research it read 110Volts.
:thank You,
:Vinny
::Vinny: it will probably receive the AM broadcast band. Does the tuning dial show the covered frequencies?
::If it's an AC set, it will probably be designed for 220V.
::A single cap should have just one voltage rating. 15kV wouldn't make sense to me.
::1 pF = 1 uuF = (10^-6) uF
::Doug
:::I was given a french radio, would it play in the US and receive the regular radio stations?
:::Also I took it apart to see how to change the caps, they were rated in PF and appeared to be tubular plastic which seem to crack easy.
:::I saw a couple of caps that read:
:::25,000 PF
:::500 / 15,000 volts
:::Is that an unusual amount of voltage, can that be real, which is it, 500volts or 15, 000volts? can these type of caps be bought?
:::Thank you,
:::Vinny
