What's really confusing me though is the schematic representation of the capacitor bank. If you look at the schematic (Motorola 59T2 Item 20 ) it looks like red and black wire is going to the 15uF, the green is going to a 10 uF and the 20 uF is grounded. But what wire is supposed to be going to the 20uF??? This is really confusing, especially since I need to replace this part. Can anyone make heads of tails out of this?
I assume the ground is the common link between all the capacitors.
Steve
The Black wire is common to all three capacitors and is at -15V. The Yellow wire that goes to ground is the positive side of the 20uF capacitor.
The Green wire is the positive side of the 10uF capacitor.
The Red wire is the positive side of the 15uF capacitor.
John
:The Black wire is common to all three capacitors and is at -15V. The Yellow wire that goes to ground is the positive side of the 20uF capacitor.
:The Green wire is the positive side of the 10uF capacitor.
:The Red wire is the positive side of the 15uF capacitor.
:John
John
:Great, thanks John. You're a BIG help! After I wrote the last post I had an inkling that the black might be the common wire - but it seemed an odd configuration since I believe the common wire is usually the ground. Just curious though how did you come up with -15V?
::The Black wire is common to all three capacitors and is at -15V. The Yellow wire that goes to ground is the positive side of the 20uF capacitor.
::The Green wire is the positive side of the 10uF capacitor.
::The Red wire is the positive side of the 15uF capacitor.
::John
:If you look at the table of socket voltages you will see a note for pin 4 of the #41 output tube. -15V at the bias resistor. It's developed from the current through the series of the 330 ohm and 68 ohm resistors connected from the center tap of the transformer to ground.
:John
::Great, thanks John. You're a BIG help! After I wrote the last post I had an inkling that the black might be the common wire - but it seemed an odd configuration since I believe the common wire is usually the ground. Just curious though how did you come up with -15V?
:::The Black wire is common to all three capacitors and is at -15V. The Yellow wire that goes to ground is the positive side of the 20uF capacitor.
:::The Green wire is the positive side of the 10uF capacitor.
:::The Red wire is the positive side of the 15uF capacitor.
:::John
As Del mentioned you should replace the E caps.
The crackling sound could be coming from dirty/oxidized tube socket contacts or a dirty volume control. Also ensure that the tuning capacitor plates are not touching.
Gary
:Well, I replaced all the caps in my radio (Motorola aka Galvin 59T2) except for a ganged electrolytic capacitor bank (10, 20, 15 uF) and a .03uf cap. When I turned it on I still get this continuous crackling sound. It goes away when I hit a strong station but you can definitely hear it over the weaker stations. Now I'm not sure how a tube radio should sound, so I don't know if this is normal. Should the interstation regions be a lot quieter/less noisy? I have a feeling that its the cap bank and those large electrolytics that need to be replaced but I'm not sure how to break up that large ganged cap bank into 3 individual caps. It doesn't show polarity in the schematic (Item #20). Any feedback on this is appreciated. Thanks, Steve
:Hi Steve,
:As Del mentioned you should replace the E caps.
:The crackling sound could be coming from dirty/oxidized tube socket contacts or a dirty volume control. Also ensure that the tuning capacitor plates are not touching.
:Gary
:How long is your antenna? Did you check the antenna coil?
:Bill
:Right now my antenna is just a 5ft 20 guage wire. I wasn't sure how to check the antenna coil since its covered in wax. Can I check it for continuity on my ohmmeter?
::How long is your antenna? Did you check the antenna coil?
::Bill
:Wax is good. Yes use your ohm setting on meter. Don't have power applied. The wax antenna coils has terminals/connections. On schematic item 1 is the antenna coil. Follow the leads. Blue to chassis is primary side, white to white/green is secondary. You want continuity. Don't worry now with resistance .
:Bill
::Right now my antenna is just a 5ft 20 guage wire. I wasn't sure how to check the antenna coil since its covered in wax. Can I check it for continuity on my ohmmeter?
:::How long is your antenna? Did you check the antenna coil?
:::Bill
