Johnny:
If that choke checks OK with an Ohmmeter, it is probably good. They seldom short. (But they do)
::Okay Edd, Ive taken the steps recommended and I still have static. No connections with LC test capability. I can move it slightly with a plastic tool and it goes away but returns later. So if replacement is necessary do I replace it with one of the "Typical 2.5MH or 1MH" chokes? They are available but of course look nothing like the one that is in the radio. It shouldn't hurt to just try a 2.5MH or 1MH to see if one works should it? Thanks!
::That is a Radio Frequency Choke on the plate of the combined detector / AF driver stage where there initially is RF and detected
:: audio combined, with just about all of the RF present initially being bypassed off to ground via the initial .001 ufd connected onto the ’27’s plate circuitry, then with that choke coil doing the final coup de grace on the remaining RF present before getting to the AF driver transformer primary. .
::The unit is probably the typical 2.5 MH value, or possibly might be as low as 1MH. If you have connections to a person / lab with
::L/C measurement capabilities, it could be confirmed on your old unit. .
::Not sure if you might still have old insulation presenting arc-over possibilities or even arcing to any core slug materiel. .
::If my problem to solve I would fire up the set again and confirm that the unit would still react to mechanical movement with a NON METALLIC object being used to flex it with, otherwise a moving metal screwdriver blade in its proximity, just might give you a “guitar pickup” effect to then be amplified. .
::If the static effect is still present, for sake of test evaluation, just lift the incoming and outgoing wiring from the unit so that they can then be interconnected. That way, you would have any leakage to ground also covered…..then evaluate to see if all is quiet now.
::If so, then you would be in the market for one of those old style RFC coils. .
::Standing by for any feedback. . . . .
::73's de Edd
The one real answer which I did not confirm a reply to , was the lifting of the connecting wiring to the coil and then the direct interconnecting of that wiring, such as to be bypassing the use of the coil totally, and the evaluation of the set then.
That would additionally cover the latter aspect of the coil having breakdown to its core.
Have you tapped and flexed immediately adjunct components, to confirm if it might be one of them, instead ?
