John
:Hi John, I had some luck soaking them in warm water, one I put in a damp dishwasher over night and it came right off that worked the best. Just make sure the wife knows its in there and doesn't turn the darn thing on. Good Luck, George T.
I remove mine with lacquer thinner. Wet the label, wait 5 minutes, wet again, wait another 5 minutes and use an Olfa blade out of the knife and work slowly giving the blade a 45 degrees angle while rocking the blade under the label -keep the label wet at all time and work in a well ventilated area-. Sandwich the label once removed between two metal plates or glass panes and let dry. Before applying the label to the restored radio, scan for the archives then spray one or two thin coats of satin lacquer (not gloss) to protect the label for years to come. I use Elmer's carpenter glue or a glue pen to reaffix the label to the radio.
Syl
Thanks Syl, the lacquer thinner did the trick. I tried it on the bottom outside sticker which was in bad shape. It didn't hurt it it all. There was still sticky glue on the back after removing it so I didn't dry it between plates. I was afraid it would stick. It came out flat anyhow. Now I feel confident to do the schematic and parts list.
John
Good point. Waxed paper would keep it from sticking but if the label is flat as you experienced, that last step isn't necessary. Glad it worked for you too and thanks for the update.
Dunno if this midget has a metal cabinet, but the one I restored for a friend came out just like an original paint job using Krylon spray paint. Dupli-color (car touch up paint) also works wonder but it is hard to find non-metallic types. I prefer Krylon though being thicker it hides tiny surface scratches on the metal cabinet.
Syl
It's metal. It's an 8004 model. I've been thinking about powdercoating it. I've used Krylon on other projects and like it. I guess I could at least try out the color scheme I'm thinking of in Krylon since it's easy to remove.
Maybe this is a sin; the color would be a blue chasis, yellow "Silvertone" logo, and a red dial. Basically Superman colors.
John
mmmm...powder coating...THAT is an idea. If you go ahead I'm interested to see the results. There is a small company in my area offering powder coating. I might be tempted to use it on my next metal cabinet project.
:Maybe this is a sin; the color would be a blue chasis, yellow "Silvertone" logo, and a red dial. Basically Superman colors.
Nah, it is your radio. You can do whatever you want. Besides, it is only a _radio_.
Syl
I'd love to know how he managed to do powder coating on a Bakelite set. It is non-conductive.
Syl
:::Thanks, but that didn't work either. I'm starting to think they used a resorcinol glue.
::I remove mine with lacquer thinner. Wet the label, wait 5 minutes, wet again, wait another 5 minutes and use an Olfa blade out of the knife and work slowly giving the blade a 45 degrees angle while rocking the blade under the label -keep the label wet at all time and work in a well ventilated area-. Sandwich the label once removed between two metal plates or glass panes and let dry. Before applying the label to the restored radio, scan for the archives then spray one or two thin coats of satin lacquer (not gloss) to protect the label for years to come. I use Elmer's carpenter glue or a glue pen to reaffix the label to the radio.
::Syl
:Thanks Syl, the lacquer thinner did the trick. I tried it on the bottom outside sticker which was in bad shape. It didn't hurt it it all. There was still sticky glue on the back after removing it so I didn't dry it between plates. I was afraid it would stick. It came out flat anyhow. Now I feel confident to do the schematic and parts list.
:John
