crosley 515
9/3/2008 4:39:38 PMClay
Am trying to bring back a crosley 515,found some caps I havnt seen before 8-450 and a 6-450 dont see any polorazation to tell me they are electrolytics,can anyone help.
Thanks,Clay
9/3/2008 5:31:41 PMjayw
Hi Clay,
Yes those are electrolytics - items 6Y & 6Z on the schematic. The positive ends are tied to the chassis. You can replace both with 10mf 450v caps.
Jim
:Am trying to bring back a crosley 515,found some caps I havnt seen before 8-450 and a 6-450 dont see any polorazation to tell me they are electrolytics,can anyone help.
: Thanks,Clay
9/3/2008 5:35:33 PMjayw
:Hi Clay,
:Yes those are electrolytics - items 6Y & 6Z on the schematic. The positive ends are tied to the chassis. You can replace both with 10mf 450v caps.
:Jim
I Should mention that there are a couple of 2 section caps in this chassis with 1 wire in each end and a strap to ground in the center (7Y & 7Z, 8Y & 8Z, 10Y & 10Z) these can be replaced with individual caps.
Jim
::Am trying to bring back a crosley 515,found some caps I havnt seen before 8-450 and a 6-450 dont see any polorazation to tell me they are electrolytics,can anyone help.
:: Thanks,Clay
9/3/2008 5:38:11 PMjayw
::Hi Clay,
::Yes those are electrolytics - items 6Y & 6Z on the schematic. The positive ends are tied to the chassis. You can replace both with 10mf 450v caps.
::Jim
:I Should mention that there are a couple of 2 section caps in this chassis with 1 wire in each end and a strap to ground in the center (7Y & 7Z, 8Y & 8Z, 10Y & 10Z) these can be replaced with individual caps.
:Jim
Missed 11y & 11z.
:::Am trying to bring back a crosley 515,found some caps I havnt seen before 8-450 and a 6-450 dont see any polorazation to tell me they are electrolytics,can anyone help.
::: Thanks,Clay
9/3/2008 5:51:40 PMSteve - W9DX
: Thanks,Clay
Clay: looks like those 2 are in one can from the schematic (http://www.nostalgiaair.org/PagesByModel/373/M0003373.pdf). You can use electrolytics there. You might want to use 10 mfd for better filtering. The 6Z designation on the schematic for the 8 mfd cap, the positive end goes to the rectifier cathode, and the negative to the common negative (heavy line) which is B-. The 6Y cap negative goes to common negative B-, and the positive to the B+ line.
Steve
9/3/2008 8:21:13 PMjayw
I went back and read my first post - I can't believe that I got the polarity backwards.
Jim
:: Thanks,Clay
:Clay: looks like those 2 are in one can from the schematic (http://www.nostalgiaair.org/PagesByModel/373/M0003373.pdf). You can use electrolytics there. You might want to use 10 mfd for better filtering. The 6Z designation on the schematic for the 8 mfd cap, the positive end goes to the rectifier cathode, and the negative to the common negative (heavy line) which is B-. The 6Y cap negative goes to common negative B-, and the positive to the B+ line.
:Steve
9/3/2008 10:10:04 PMSteve - W9DX
Yea, I think that schematic with the tube diagrams upside down and all the filament wirings had us all doing a double-take.
Steve
9/4/2008 10:08:12 PMClay
: Thanks,Clay
