I will be removing the transformers to investigate this phenomenon.
However, I do remember a post on this some time ago. Has anyone experienced this? Aside from tightening the screws, what else can be done to eliminate the buzz.
Gary
Gary
:Kinda sounds like the core laminations are loose and buzzing when you apply power. As power is applied, magnetic flux flows around the core and can force same polarity laminations apart. Does it sound like a 120hz buzz? See if it's possible to tighten the screws or bolts holding the laminations together.
:Steve
Yeah ! Way to go Gary!
Syl - from Québec
Bill from D.C. (not B.C.)
I find it odd you've never head of Robertson heads. I suspect you've seen them but never knew the real name.
The best fastening system on earth.
http://www.robertsonscrew.com/
Syl
Best Regards,
Bill Grimm
:::Could you explain "Robertson" heads for those of us who are Canadian challenged?
:::Bill from D.C. (not B.C.)
::I find it odd you've never head of Robertson heads. I suspect you've seen them but never knew the real name.
::The best fastening system on earth.
::http://www.robertsonscrew.com/
::Syl
:Hi Zyl,
: I see it now, a square driver fitting into a square hole on the screw. I have a driver in a set of bits, but have never seen a screw.
: I didn't think I was that far from Toronto. I listen to CHWO every night.
:Best Regards,
:Bill Grimm
