infor.-Samson Electric Co. Type PAM 39 Amp
8/24/2008 8:54:50 PMDan Livesay
Hello- I recently acquired a Samson type PAM 39 135 watt P 8390 amplifier made by the Samson Electric Co. Watertown Mass.This information is from the metal attached plate.So far this is all I have been able to find. This amp has two 81 rectifiers-two 24 pre amps-two 250 power amps.Any help will be appreciated.
8/24/2008 10:31:06 PMRadiodoc
Dan,
Here is a schematic for a PAM 39 amp.
http://www.nostalgiaair.org/PagesByModel/686/M0043686.pdf
:Hello- I recently acquired a Samson type PAM 39 135 watt P 8390 amplifier made by the Samson Electric Co. Watertown Mass.This information is from the metal attached plate.So far this is all I have been able to find. This amp has two 81 rectifiers-two 24 pre amps-two 250 power amps.Any help will be appreciated.
8/25/2008 7:14:30 AMDan Livesay
:Dan,
:Here is a schematic for a PAM 39 amp.
:http://www.nostalgiaair.org/PagesByModel/686/M0043686.pdf
:Radiodoc
:Thanks Radiodoc-that was fast
::Hello- I recently acquired a Samson type PAM 39 135 watt P 8390 amplifier made by the Samson Electric Co. Watertown Mass.This information is from the metal attached plate.So far this is all I have been able to find. This amp has two 81 rectifiers-two 24 pre amps-two 250 power amps.Any help will be appreciated.
9/23/2013 2:03:18 PMKen Danckaert
I just came across this post. I have a Samson amp PAM and it is either 61 or 51. Not sure which. I need a schematic for it. Know rhere I can find it>
Ken
::Dan,
::Here is a schematic for a PAM 39 amp.
::http://www.nostalgiaair.org/PagesByModel/686/M0043686.pdf
::Radiodoc
::Thanks Radiodoc-that was fast
:::Hello- I recently acquired a Samson type PAM 39 135 watt P 8390 amplifier made by the Samson Electric Co. Watertown Mass.This information is from the metal attached plate.So far this is all I have been able to find. This amp has two 81 rectifiers-two 24 pre amps-two 250 power amps.Any help will be appreciated.
