Dial light
8/24/2008 2:33:14 PMVinny
I am working on a GE 114w, this radio has no dial light. Is there any way to install a dial light?
Can a seperate transformer be built into the AC power line to power a light?
Vinny
8/24/2008 3:25:43 PMJohnny
:I am working on a GE 114w, this radio has no dial light. Is there any way to install a dial light?
:Can a seperate transformer be built into the AC power line to power a light?
:Vinny
:In my experience dial lamps are usually powered by the heater voltage on the tubes but in your case your heater voltages run around 35 volts. I don't know of a lamp that fits that spec. You could use a type T4, NE45 lamp that is 105-125 volts and come off of your power switch. This bulb however has a current rating of .002 amps.
8/24/2008 4:02:19 PMNorm Leal
Vinny
You could add a transformer but it takes room. How about a lamp and cap in series with the AC line? Probably need Zener diodes so lamp doesn't flash at turn on.
Your radio already has a 35Z5 rectifier. It's made to operate a lamp but requires a little wiring change.
Remove resistor R9 (22 ohms) from pin #2. Connect it to pin #3 instead. Add a #47 lamp between pins #2 and #3. That's a simple change making your GE like other radios with a dial lamp.
http://www.nostalgiaair.org/PagesByModel/590/M0007590.pdf
::I am working on a GE 114w, this radio has no dial light. Is there any way to install a dial light?
::Can a seperate transformer be built into the AC power line to power a light?
::Vinny
::In my experience dial lamps are usually powered by the heater voltage on the tubes but in your case your heater voltages run around 35 volts. I don't know of a lamp that fits that spec. You could use a type T4, NE45 lamp that is 105-125 volts and come off of your power switch. This bulb however has a current rating of .002 amps.
8/30/2008 12:20:47 PMVinny
Norm, as I was trying to move the resistor it cracked...it's r9 @22ohm and 1/2 watt..I want to order one but do not know the wattage or what type to buy?
Vinny
:Vinny
: You could add a transformer but it takes room. How about a lamp and cap in series with the AC line? Probably need Zener diodes so lamp doesn't flash at turn on.
: Your radio already has a 35Z5 rectifier. It's made to operate a lamp but requires a little wiring change.
: Remove resistor R9 (22 ohms) from pin #2. Connect it to pin #3 instead. Add a #47 lamp between pins #2 and #3. That's a simple change making your GE like other radios with a dial lamp.
:http://www.nostalgiaair.org/PagesByModel/590/M0007590.pdf
:::I am working on a GE 114w, this radio has no dial light. Is there any way to install a dial light?
:::Can a seperate transformer be built into the AC power line to power a light?
:::Vinny
:::In my experience dial lamps are usually powered by the heater voltage on the tubes but in your case your heater voltages run around 35 volts. I don't know of a lamp that fits that spec. You could use a type T4, NE45 lamp that is 105-125 volts and come off of your power switch. This bulb however has a current rating of .002 amps.
8/30/2008 12:43:30 PMNorm Leal
Hi Vinny
In another thread someone mentioned Radio Shack has them. If you don't have a Radio Shack nearby email you address. Something like that I can send in an envelope.
:Norm, as I was trying to move the resistor it cracked...it's r9 @22ohm and 1/2 watt..I want to order one but do not know the wattage or what type to buy?
:Vinny
::Vinny
:: You could add a transformer but it takes room. How about a lamp and cap in series with the AC line? Probably need Zener diodes so lamp doesn't flash at turn on.
:: Your radio already has a 35Z5 rectifier. It's made to operate a lamp but requires a little wiring change.
:: Remove resistor R9 (22 ohms) from pin #2. Connect it to pin #3 instead. Add a #47 lamp between pins #2 and #3. That's a simple change making your GE like other radios with a dial lamp.
::http://www.nostalgiaair.org/PagesByModel/590/M0007590.pdf
::::I am working on a GE 114w, this radio has no dial light. Is there any way to install a dial light?
::::Can a seperate transformer be built into the AC power line to power a light?
::::Vinny
::::In my experience dial lamps are usually powered by the heater voltage on the tubes but in your case your heater voltages run around 35 volts. I don't know of a lamp that fits that spec. You could use a type T4, NE45 lamp that is 105-125 volts and come off of your power switch. This bulb however has a current rating of .002 amps.
8/31/2008 9:00:18 PMVinny
Norm, I purchased the resistor at radio shack. Is there a certain direction direction that they go. I would assume they match the same with the red lines on the 5th. pin to the left where the other one was?
Vinny
:Hi Vinny
: In another thread someone mentioned Radio Shack has them. If you don't have a Radio Shack nearby email you address. Something like that I can send in an envelope.
::Norm, as I was trying to move the resistor it cracked...it's r9 @22ohm and 1/2 watt..I want to order one but do not know the wattage or what type to buy?
::Vinny
:::Vinny
::: You could add a transformer but it takes room. How about a lamp and cap in series with the AC line? Probably need Zener diodes so lamp doesn't flash at turn on.
::: Your radio already has a 35Z5 rectifier. It's made to operate a lamp but requires a little wiring change.
::: Remove resistor R9 (22 ohms) from pin #2. Connect it to pin #3 instead. Add a #47 lamp between pins #2 and #3. That's a simple change making your GE like other radios with a dial lamp.
:::http://www.nostalgiaair.org/PagesByModel/590/M0007590.pdf
:::::I am working on a GE 114w, this radio has no dial light. Is there any way to install a dial light?
:::::Can a seperate transformer be built into the AC power line to power a light?
:::::Vinny
:::::In my experience dial lamps are usually powered by the heater voltage on the tubes but in your case your heater voltages run around 35 volts. I don't know of a lamp that fits that spec. You could use a type T4, NE45 lamp that is 105-125 volts and come off of your power switch. This bulb however has a current rating of .002 amps.
8/31/2008 11:10:38 PMNorm Leal
Vinny
In another thread someone mentioned resistors don't have polarity. I'll post it here also. Stripes only indicate value.
:Norm, I purchased the resistor at radio shack. Is there a certain direction direction that they go. I would assume they match the same with the red lines on the 5th. pin to the left where the other one was?
:Vinny
::Hi Vinny
:: In another thread someone mentioned Radio Shack has them. If you don't have a Radio Shack nearby email you address. Something like that I can send in an envelope.
:::Norm, as I was trying to move the resistor it cracked...it's r9 @22ohm and 1/2 watt..I want to order one but do not know the wattage or what type to buy?
:::Vinny
::::Vinny
:::: You could add a transformer but it takes room. How about a lamp and cap in series with the AC line? Probably need Zener diodes so lamp doesn't flash at turn on.
:::: Your radio already has a 35Z5 rectifier. It's made to operate a lamp but requires a little wiring change.
:::: Remove resistor R9 (22 ohms) from pin #2. Connect it to pin #3 instead. Add a #47 lamp between pins #2 and #3. That's a simple change making your GE like other radios with a dial lamp.
::::http://www.nostalgiaair.org/PagesByModel/590/M0007590.pdf
::::Norm
::::::I am working on a GE 114w, this radio has no dial light. Is there any way to install a dial light?
::::::Can a seperate transformer be built into the AC power line to power a light?
::::::Vinny
::::::In my experience dial lamps are usually powered by the heater voltage on the tubes but in your case your heater voltages run around 35 volts. I don't know of a lamp that fits that spec. You could use a type T4, NE45 lamp that is 105-125 volts and come off of your power switch. This bulb however has a current rating of .002 amps.
8/31/2008 11:33:57 PMVinny
Norm, I did it and it works...yahooooooooooo...Thank you so much for your help. Now I have to find a way to attach the bulb socket to the chassis...Thank you again for your help...
Vinny
:Vinny
: In another thread someone mentioned resistors don't have polarity. I'll post it here also. Stripes only indicate value.
::Norm, I purchased the resistor at radio shack. Is there a certain direction direction that they go. I would assume they match the same with the red lines on the 5th. pin to the left where the other one was?
::Vinny
:::Hi Vinny
::: In another thread someone mentioned Radio Shack has them. If you don't have a Radio Shack nearby email you address. Something like that I can send in an envelope.
::::Norm, as I was trying to move the resistor it cracked...it's r9 @22ohm and 1/2 watt..I want to order one but do not know the wattage or what type to buy?
::::Vinny
:::::Vinny
::::: You could add a transformer but it takes room. How about a lamp and cap in series with the AC line? Probably need Zener diodes so lamp doesn't flash at turn on.
::::: Your radio already has a 35Z5 rectifier. It's made to operate a lamp but requires a little wiring change.
::::: Remove resistor R9 (22 ohms) from pin #2. Connect it to pin #3 instead. Add a #47 lamp between pins #2 and #3. That's a simple change making your GE like other radios with a dial lamp.
:::::http://www.nostalgiaair.org/PagesByModel/590/M0007590.pdf
:::::Norm
:::::::I am working on a GE 114w, this radio has no dial light. Is there any way to install a dial light?
:::::::Can a seperate transformer be built into the AC power line to power a light?
:::::::Vinny
:::::::In my experience dial lamps are usually powered by the heater voltage on the tubes but in your case your heater voltages run around 35 volts. I don't know of a lamp that fits that spec. You could use a type T4, NE45 lamp that is 105-125 volts and come off of your power switch. This bulb however has a current rating of .002 amps.
8/24/2008 3:55:20 PMDoug Criner
Vinny: That set uses a 35Z5 rectifier, which has a lamp tap on the filament - the tap is unused on your model.
You should measure about 7.5 V between pins 2 and 3. With a #40 or #47 lamp, that voltage will drop to about 5.5 V, enough for the lamp.
Doug
:Vinny
8/24/2008 11:43:55 PMVinny
Doug, thank you for replying.
I am waiting to get and install a cord so I cannot check for voltage. When you say tap I believe you mean the terminal from the tube socket underneath the chassis?
Pins (under the chassis)from the socket #'s 1 and 3 are open with no connections. Pins 2 and 3 have polarity. So when I get the cord you want me to test voltage (I believe that would be DC)between 2 qnd 3?
7 and 2 also check for polarity (I believe that is the heater (Cathode).
Would adding a bulb and bulb socket stress the radio circuits?
Vinny
:Vinny: That set uses a 35Z5 rectifier, which has a lamp tap on the filament - the tap is unused on your model.
:You should measure about 7.5 V between pins 2 and 3. With a #40 or #47 lamp, that voltage will drop to about 5.5 V, enough for the lamp.
:Doug
::Vinny
8/24/2008 11:49:53 PMVinny
Doug, I also got this information:
:Doug
::Vinny
8/25/2008 12:13:06 AMDoug Criner
Vinny, do what Norm says - now and always!
But No, it won't hurt your radio.
Doug
:Doug, I also got this information:
:Remove resistor R9 (22 ohms) from pin #2. Connect it to pin #3 instead. Add a #47 lamp between pins #2 and #3. That's a simple change making your GE like other radios with a dial lamp.
::Vinny: That set uses a 35Z5 rectifier, which has a lamp tap on the filament - the tap is unused on your model.
::You should measure about 7.5 V between pins 2 and 3. With a #40 or #47 lamp, that voltage will drop to about 5.5 V, enough for the lamp.
::Doug
:::Vinny
8/25/2008 1:10:07 PMLewis Linson
Vinny, look at the schematic for a G. E. model 119. That's almost the same radio with a pilot light.
:But No, it won't hurt your radio.
:Doug
::Doug, I also got this information:
::Remove resistor R9 (22 ohms) from pin #2. Connect it to pin #3 instead. Add a #47 lamp between pins #2 and #3. That's a simple change making your GE like other radios with a dial lamp.
:::Vinny: That set uses a 35Z5 rectifier, which has a lamp tap on the filament - the tap is unused on your model.
:::You should measure about 7.5 V between pins 2 and 3. With a #40 or #47 lamp, that voltage will drop to about 5.5 V, enough for the lamp.
:::Doug
::::Vinny
