: Hello, I have an Eico HF-81 that uses a common 165 ohm cathode resistor bypassed with a 50uF cap in each output stage. The plate voltage is 335v and cathode 12v, it uses no ultralinear. I read that using seperate cathode resistors limits out of balance voltage in the primary of the output transformer. What would be the resistor values for each tube? What are the pros and cons of this method verses using a common resistor?
Hello, two separate cathode resistors of 330 ohms would
do the trick. Remember, you will need two separate cathode-bypass
capacitors also. I dont see any advantage in two separate cathode
resistors. A single resistor circuit (stock) would tend
to keep the two tubes in balance, exactly what you want
it to do.
