I have an Atwater kent model 55C. In looking at the schematic, it looks like the unit uses a speaker with a field coil. The coil looks like it is powered off of a tap on the negative side of the power supply.
Can I run a high Z PM speaker (2000 ohm) on this radio?
What happens to the PS if the field loading is not there ( i.e. PM speaker has no field).?
Lou
You can jury rig a 2500 power resistor in place of the field coil, but there will likely be extra hum. Or, you can replace the field coil with a suitable choke.
The AK F-4 speaker was tailor made for the 55. That would be you best bet. If you buy one, make sure it comes with the speaker plug, which is non-standard.
Doug
:All:
:I have an Atwater kent model 55C. In looking at the schematic, it looks like the unit uses a speaker with a field coil. The coil looks like it is powered off of a tap on the negative side of the power supply.
:Can I run a high Z PM speaker (2000 ohm) on this radio?
:What happens to the PS if the field loading is not there ( i.e. PM speaker has no field).?
:Thanks
:Lou
This is a 55C.
According to the schematic, the B= is continuous in the power supply. The field coil is in parallel with the B=, not in seties with it.
Lou
::Lou: With a PM speaker, and no field coil, the radio won't work. There will be no B+ voltage.
::You can jury rig a 2500 power resistor in place of the field coil, but there will likely be extra hum. Or, you can replace the field coil with a suitable choke.
::The AK F-4 speaker was tailor made for the 55. That would be you best bet. If you buy one, make sure it comes with the speaker plug, which is non-standard.
::Doug
:::All:
:::I have an Atwater kent model 55C. In looking at the schematic, it looks like the unit uses a speaker with a field coil. The coil looks like it is powered off of a tap on the negative side of the power supply.
:::Can I run a high Z PM speaker (2000 ohm) on this radio?
:::What happens to the PS if the field loading is not there ( i.e. PM speaker has no field).?
:::Thanks
:::Lou
I now see what you're saying. Sorry.
However, without the field coil, the B+ will be high, and maybe more hum. Best to replace it with a 1100-ohm power resistor.
:Doug:
:This is a 55C.
:According to the schematic, the B= is continuous in the power supply. The field coil is in parallel with the B=, not in seties with it.
:Lou
:::Lou: With a PM speaker, and no field coil, the radio won't work. There will be no B+ voltage.
:::You can jury rig a 2500 power resistor in place of the field coil, but there will likely be extra hum. Or, you can replace the field coil with a suitable choke.
:::The AK F-4 speaker was tailor made for the 55. That would be you best bet. If you buy one, make sure it comes with the speaker plug, which is non-standard.
:::Doug
::::All:
::::I have an Atwater kent model 55C. In looking at the schematic, it looks like the unit uses a speaker with a field coil. The coil looks like it is powered off of a tap on the negative side of the power supply.
::::Can I run a high Z PM speaker (2000 ohm) on this radio?
::::What happens to the PS if the field loading is not there ( i.e. PM speaker has no field).?
::::Thanks
::::Lou
