flexible wire wound resistors - Sparton 57
8/17/2008 7:49:29 PMBrian
I have found two flexible wire wound resistors (R16 and R17) in this radio (1936 Canadian Sparton model 57). One had drifted high and the other one is broken. To replace these would carbon 2 watt resistors work OK?
8/17/2008 8:12:52 PMGary W. Prutchick
Hi Brian,
Forgive me if this is a stupid question, but, what do you mean by "flexible wire wound resistor"?
Gary
:I have found two flexible wire wound resistors (R16 and R17) in this radio (1936 Canadian Sparton model 57). One had drifted high and the other one is broken. To replace these would carbon 2 watt resistors work OK?
8/17/2008 8:30:33 PMBrian
They look like shielded wire with metal ends but are apparently a form of resistor.
:Hi Brian,
:Forgive me if this is a stupid question, but, what do you mean by "flexible wire wound resistor"?
:Gary
::I have found two flexible wire wound resistors (R16 and R17) in this radio (1936 Canadian Sparton model 57). One had drifted high and the other one is broken. To replace these would carbon 2 watt resistors work OK?
8/17/2008 8:48:45 PMDoug Criner
Brian: Yes.
Here's the schematic and parts list: http://www.nostalgiaair.org/PagesByModel/739/M0029739.pdf
R16 and R17 are shown as 2-W resistors. Doesn't make any difference whether carbon, wire-wound, flexible, or whatever.
Doug
:::I have found two flexible wire wound resistors (R16 and R17) in this radio (1936 Canadian Sparton model 57). One had drifted high and the other one is broken. To replace these would carbon 2 watt resistors work OK?
8/17/2008 8:51:13 PMDoug Criner
By the way, it is unusual for a wire-wound resistor to drift up in value. Double check it.
Doug
:Brian: Yes.
:Here's the schematic and parts list: http://www.nostalgiaair.org/PagesByModel/739/M0029739.pdf
:R16 and R17 are shown as 2-W resistors. Doesn't make any difference whether carbon, wire-wound, flexible, or whatever.
:Doug
::::I have found two flexible wire wound resistors (R16 and R17) in this radio (1936 Canadian Sparton model 57). One had drifted high and the other one is broken. To replace these would carbon 2 watt resistors work OK?
8/17/2008 8:51:32 PMBrian
Thanks Doug.
:Brian: Yes.
:Doug
8/20/2008 3:11:58 PMRadiodoc
Gary,
Check out:
http://www.philcorepairbench.com/flexrest.htm
:Hi Brian,
:Gary
