any idea on what the problem may be?
Might also clean & check band switch contacts.
http://www.nostalgiaair.org/PagesByModel/549/M0025549.pdf
::Have you performed an alignment yet? Often this is necessary after rework of the radio.
::I have a zenith TO H500, later model 5h40 chassis. It was in really nice shape. I just finished re-capping all the paper caps and electrolytics. Works really well now on all bands EXCEPT broadcast. I pull in stations strong on all shortwave bands but on broadcast it is weak. The stations have much variability in volume and low freq stations (near 550) are very weak no matter what antenna I use.
::any idea on what the problem may be?
:Hi
: Might also clean & check band switch contacts.
:http://www.nostalgiaair.org/PagesByModel/549/M0025549.pdf
:::Have you performed an alignment yet? Often this is necessary after rework of the radio.
:::I have a zenith TO H500, later model 5h40 chassis. It was in really nice shape. I just finished re-capping all the paper caps and electrolytics. Works really well now on all bands EXCEPT broadcast. I pull in stations strong on all shortwave bands but on broadcast it is weak. The stations have much variability in volume and low freq stations (near 550) are very weak no matter what antenna I use.
:::any idea on what the problem may be?
:Bandswitch contacts make alot of sense in light of the strong performance on other bands. The contacts are buried in the coil assembly so I'm not sure I gave that much attention. Stay tuned.
::Hi
:: Might also clean & check band switch contacts.
::http://www.nostalgiaair.org/PagesByModel/549/M0025549.pdf
::::Have you performed an alignment yet? Often this is necessary after rework of the radio.
::::I have a zenith TO H500, later model 5h40 chassis. It was in really nice shape. I just finished re-capping all the paper caps and electrolytics. Works really well now on all bands EXCEPT broadcast. I pull in stations strong on all shortwave bands but on broadcast it is weak. The stations have much variability in volume and low freq stations (near 550) are very weak no matter what antenna I use.
::::any idea on what the problem may be?
