At a listening spot in central Texas ther appears to be a almost imprceptable continuous time marker broadcast at about 663 KHZ. Distinctive clicks, spaced one second apart, can be heard through the background US ideband scatter from multiple US 660 KHZ stations, and from South American stations that are spaced less than 10 KHZ apart. Unfortunately there is a strong local station at 970, which does not allow me to pinpoint the exact time signal frequency. The signal is best heard about 10:00 PM Central time on a radio with narrow bandwidth. The voice ID is a foriegn language, and is unintelligible. Does anyone know what this time signal broadcast is, and where it originates. The signal can be heard on several radios, which rules out a receiver proble
Sorry - my computer is hiccuping. Thanks for your help
If you have a digital receiver you might check out that you are right ON 4795
frequency, and at the proper time of propagation for that frequency band, see
if that is also the same signal format, don’t know if you would also have the
same luck with that 1278 signal, as some locals might be laying on top of it.
