:Thanks to all the good convincing I've decided to save the Packard Bell 771. In order to do this I am going to have to rewire it from scratch. On the schematic there is a note that says "Band Switch In Standard Broadcast Position". Does this mean that the wiring shown is just for that position or is the wiring shown the way the radio is wired regardless of what position the band switch is in? I know, simple subject for most of you but I'm still learning. Thank you!
::I kind of thought that. Thank you for clarifying it for me.
::That should be just how the contacts are shown on the diagram for the switch. Wiring is as shown on the schematic but the internal contacts rotate to make the different connections required for operation.
:::Thanks to all the good convincing I've decided to save the Packard Bell 771. In order to do this I am going to have to rewire it from scratch. On the schematic there is a note that says "Band Switch In Standard Broadcast Position". Does this mean that the wiring shown is just for that position or is the wiring shown the way the radio is wired regardless of what position the band switch is in? I know, simple subject for most of you but I'm still learning. Thank you!
