Zenith 11-S-464
8/13/2008 9:01:08 PMBob Z
Zenith Chassis 1103, I am looking for the alighment instructions. I restored one and aligned it best I could figure out, it works fine, but I am sure that the correct alignment would give better performance. My e-mail is in the heading.
Any response is appreciated.
Thanks Bob.
8/13/2008 9:33:36 PMJohnny
:Zenith Chassis 1103, I am looking for the alighment instructions. I restored one and aligned it best I could figure out, it works fine, but I am sure that the correct alignment would give better performance. My e-mail is in the heading.
:Any response is appreciated.
:Thanks Bob.
:Are you sure that's not a 11-S-474? The 474 has the 1103 chassis and it is practically identical to my 10-S-668. Radioera.com I believe is a pay site but they have most Zenith info if you can't find it through places like bama. gn4radios.com is another Zenith site. Be patient. Someone else here might have better info.
8/13/2008 10:08:07 PMBob Z
It use's 1 tube for detector and af amp, schmatic for the 1103 shows both configuration's. Otherwise both models seem to be identical.
::Zenith Chassis 1103, I am looking for the alighment instructions. I restored one and aligned it best I could figure out, it works fine, but I am sure that the correct alignment would give better performance. My e-mail is in the heading.
::Any response is appreciated.
::Thanks Bob.
::Are you sure that's not a 11-S-474? The 474 has the 1103 chassis and it is practically identical to my 10-S-668. Radioera.com I believe is a pay site but they have most Zenith info if you can't find it through places like bama. gn4radios.com is another Zenith site. Be patient. Someone else here might have better info.
8/16/2008 12:21:34 PMSteve - W9DX
Bob: I have a Zenith 11-S-474 with the alignment instructions. pdf file is on the way to you.
Steve
