:I am restoring a couple of radios that use dial lamp #47. Is there a safe substitute or another lamp in place of this lamp that would make the dial brighter?
:Thank you
:i think u would have to worry about melting a dial scale or putting extra strain on the circuit for that. u would need the same voltage bulb but higher current which might burn hotter and strain the filament tap
::I am restoring a couple of radios that use dial lamp #47. Is there a safe substitute or another lamp in place of this lamp that would make the dial brighter?
::Thank you
Not much you can do. A #47 bulb is used in AC/DC radios with tubes having 150 ma series string filaments. If you use a higher voltage bulb there isn't enough available to light the bulb. A higher current bulb, such as #44, is also dimmer as the circuit can't supply enough current either.
If a #47 bulb is in a radio with a power transformer a #44 bulb will be brighter.
:Thank you, I guess I was trying to avoid the obvious.
::i think u would have to worry about melting a dial scale or putting extra strain on the circuit for that. u would need the same voltage bulb but higher current which might burn hotter and strain the filament tap
:::I am restoring a couple of radios that use dial lamp #47. Is there a safe substitute or another lamp in place of this lamp that would make the dial brighter?
:::Thank you
:Hi Vinny
: Not much you can do. A #47 bulb is used in AC/DC radios with tubes having 150 ma series string filaments. If you use a higher voltage bulb there isn't enough available to light the bulb. A higher current bulb, such as #44, is also dimmer as the circuit can't supply enough current either.
: If a #47 bulb is in a radio with a power transformer a #44 bulb will be brighter.
::Thank you, I guess I was trying to avoid the obvious.
:::i think u would have to worry about melting a dial scale or putting extra strain on the circuit for that. u would need the same voltage bulb but higher current which might burn hotter and strain the filament tap
::::I am restoring a couple of radios that use dial lamp #47. Is there a safe substitute or another lamp in place of this lamp that would make the dial brighter?
::::Thank you
:Thank you norm, at the risk of sounding obsessive and like a shoemaker, is it possible to surround the light (as close as possible)with say tin foil or any other reflective material.
:Vinny
::Hi Vinny
:: Not much you can do. A #47 bulb is used in AC/DC radios with tubes having 150 ma series string filaments. If you use a higher voltage bulb there isn't enough available to light the bulb. A higher current bulb, such as #44, is also dimmer as the circuit can't supply enough current either.
:: If a #47 bulb is in a radio with a power transformer a #44 bulb will be brighter.
:::Thank you, I guess I was trying to avoid the obvious.
::::i think u would have to worry about melting a dial scale or putting extra strain on the circuit for that. u would need the same voltage bulb but higher current which might burn hotter and strain the filament tap
:::::I am restoring a couple of radios that use dial lamp #47. Is there a safe substitute or another lamp in place of this lamp that would make the dial brighter?
:::::Thank you
