Seems like to me, that the highest probability for the problem is to be associative with the audio output circuits two coupling capacitors or the output tube itself. With it either being gassy, or developing grid emission.
After a reconfirmation of ZERO DC leakage, on those 2 specific capacitors, try this additionally.
Turn on the cold radio and run the volume down to zero and then take a ground referenced DC measurement of the negative grid bias on the output tubes first grid and log it. Then run up the volume and play the unit until your perceived degradation of the sound FULLY onsets. Then you drop the volume back down to zero again and measure the first grid voltage again and see if the first grid voltage has now become less negative than the initial reading then you can certainly suspicion that output tube being bad with temperature onset.
Reference Schematic Thumbnail:
:Seems like to me, that the highest probability for the problem is to be associative with the audio output circuits two coupling capacitors or the output tube itself. With it either being gassy, or developing grid emission.
:After a reconfirmation of ZERO DC leakage, on those 2 specific capacitors, try this additionally.
:Turn on the cold radio and run the volume down to zero and then take a ground referenced DC measurement of the negative grid bias on the output tubes first grid and log it. Then run up the volume and play the unit until your perceived degradation of the sound FULLY onsets. Then you drop the volume back down to zero again and measure the first grid voltage again and see if the first grid voltage has now become less negative than the initial reading then you can certainly suspicion that output tube being bad with temperature onset.
:Reference Schematic Thumbnail:
:Edd: as a test, can I put a 5oL6GT tube back in the radio from another radio as a test? The schematic says that that tube was replaced by 50A5 tube.
:Vinny
::Seems like to me, that the highest probability for the problem is to be associative with the audio output circuits two coupling capacitors or the output tube itself. With it either being gassy, or developing grid emission.
::After a reconfirmation of ZERO DC leakage, on those 2 specific capacitors, try this additionally.
::Turn on the cold radio and run the volume down to zero and then take a ground referenced DC measurement of the negative grid bias on the output tubes first grid and log it. Then run up the volume and play the unit until your perceived degradation of the sound FULLY onsets. Then you drop the volume back down to zero again and measure the first grid voltage again and see if the first grid voltage has now become less negative than the initial reading then you can certainly suspicion that output tube being bad with temperature onset.
::Reference Schematic Thumbnail:
::73's de Edd
