Hi lads.
My present project is a Magestic Model 50. It is somewhat deaf and very low volume. Any help please would be appreciated,
many thanks Frank. Doncaster England.
What have you done so far? Do you have a decent antenna connected?
First, I would check all the voltages against the table on the schematic. If any of the voltages are significantly out of line, then troubleshoot in a systematic manner. Make sure tube pins and sockets are clean.
Then replace caps, one by one, making sure you haven't introduced a new problem. Check all resistors, and replace any that are more than, say, 25% off - again, checking operation after each one is replaced.
Doug
:Hi lads.
:My present project is a Magestic Model 50. It is somewhat deaf and very low volume. Any help please would be appreciated,
:many thanks Frank. Doncaster England.
I have a good aerial in place - so since you think the problem should be easy to overcome in the 'step by step' way you suggest I will take this route.
Again. Many thanks
Frank. Doncaster. England.
There are a couple of bypass condensers that tend to leak which are concealed in the UF cnas, which are RIVETED to the chassis.
good luck!
