Thanks to any and all for assistance,
Phil Branch
It will give you two to choose from, so just select the 80.
A picture will appear of the pin layout and the filament pins are marked "F". On this tube, they are the two largest diameter pins.
Other configurations show a "key" or extruded part at the base of the tube that is used to reference the pins and what they are for. Count clockwise from the key to get to the right pin(s).
Hope this help.
Terry F
Thank You Terry, That was a simpler than I thought it would be.
Regards,
Phil
