Feedback for Edd
7/20/2008 10:16:41 PMBob Z
In reference to the golf cart charger with nothing coming out of the transformer, that you did a nice job in re-drawing my rotten attempt of drawing a transformer.
If you remember it was a fero-resonence transformer with nothing at the secondary, with it completely removed from the circuit.
I finally got back to it, the primary draws about what it should at full output, about 6-7 amps at 120 on it, no change with capacitor in or out of the circuit, and only about 2 volts on the secondary or thirarity (3rd winding, i know the spelling is wrong), it looks like there is a short somewhere and it is going into saturation and shutting down. All leads were open during the test.
So again thanks for your input.
7/21/2008 3:58:54 PMEdd
With this being separate from the original post, I guess that you are still hoping for there still being a slim possibility of the
POWER
transformateur not being KA-PUT-skies.
However, if you now have all of the secondary leads floating / disconnected, and are still reading that fierce of a primary draw, it certainly seems so.
That should definitely be true, with / since the tertiary windings resonating capacitor is also out of circuit.
7/21/2008 9:14:21 PMBob Z
No Edd, I have no hope of saving it, it went to the dump a few days ago. I just wanted to follow up and thank you for your input, especially re-drawing my sorry attempt of explaining the connectins to the transformer on the original post.
:With this being separate from the original post, I guess that you are still hoping for there still being a slim possibility of the
:POWER
:transformateur not being KA-PUT-skies.
:However, if you now have all of the secondary leads floating / disconnected, and are still reading that fierce of a primary draw, it certainly seems so.
:That should definitely be true, with / since the tertiary windings resonating capacitor is also out of circuit.
