[IMG]http://i294.photobucket.com/albums/mm95/johnfin1/mystery.jpg[/IMG]
http://www.elexp.com/t_induct.htm
WOW. . . .had to reach D E E E E E P into my NASA bag of tricks in pulling that photo out from a “black hole”. . . . . next time use TWO candles for your photographic illumination.. . .hi. . .hi.. . .lol
Nextly. . . .from Jan-3-2006 until present and you still haven’t got this enigma solved ?
Just by initial observation the cotton wiring seems to take us back to the 50-60’s vintage for the product, along with the white cased vintage diode shown just to the right side of your “what’s this ?” item, which is now being referenced to with a red arrow. Additionally, on that diode, its cathode lead seems to be tying into an inductive winding that would typically be resonating with its companion capacitive unit and hitting in the 4-5 Mhz spectrum.
I am seeing all of the old generation carbon composition resistors with one newer variant in the black sheep unit added in as the 8200 ohm unit at the top of the photo.
Looking at the pin one of what …best that I can make out… seems to be a 7 pin mini vice a 9 pin mini tube socket that is shown, apparently there is a 250K 1st grid biasing resistor tied into that pin 1 and taking its signal input from the coupling capacitor that is only~25 % visible , as is seen coming in from the extreme left bottom corner of the picture.
Then we seem to have pins 2 (tube cathode ?) and 3 (Tube filament ?) joined and connected to the center post and the cluster then getting grounded by the bare buss wire passing to the right side of the 250K grid resistor to get to chassis ground.
That then leaves green cotton wire carrying in the hot filament line to the tube, and if the adjunct yellow wire is daisy chaining on over to supply yet another tube, if so, strange that they didn’t maintain the same common green color coding ?
Now we are down to the tubes pin where your “dee-vice” connects in, which I suspect to be a plate connection with there being a 1K load resistor coming up to feed the plate and your unit then coupling off and passing amplified signal to the right.
As per the “plate resistor” value, the cameras low optical F-setting and the inherent depth of field , has left the resistor a bit out of focus across its entire depth, but I will still opt for a red band instead of an orange band as being the resistors bottom band color. That resistors sprigtail--loop--solder tack replacement even depicts the limited quality control aspects inherently learned in Soldering 101…..gouge.
Its Showtime now…..
I have placed a green markup arrow on the “Radial ceramic capacitor” to the left, and what I see is your “what’s this ?” item as being another type and manufacturers style of a like capacitor, but it being in radial lead configuration and of a 100 mmfd value. If you have measurement capabilities you could lift the lead with the easiest access and take measurement.
Also, please examine for us, the cap at the left bottom of the pic. . . .is that unit the same construction / appearance as your mystery unit ?
Lastly , give us feedback as to what this equipment is and its model / chassis number as well as the tube number in the photo.
That is just about as much as I can decipher with “nothing”.. . . .LOL
Digitally Enhanced Photo Referencing:
Thanks for the en"lighten"ment.......
Ahhhh soooo. . . . now with a mere tid-bit more of info and with that tube being a 6AU6, that tube would have its pin two. . . suppressor grid . . .going to ground, along with its cathode on pin 7 being grounded, if there is no cathode resistor, and I don’t see one.
The pin 6 screen grid should be receiving its supply resistor from the very front of the photo view, where it is void from our view.
At that units time frame I would sort of expect this unit to be a field strength meter oriented for the analysis of TV receiver frequencies . . . . which you can confirm via the instruments numerical markings. . . .plus. . . probably the presence of a turret tuner in the unit as opposed to a continuous type of tuner .
Back in those times, the tuner unit might have incorporated a 6AK5 or 6BQ7 type of tube for the frontal RF amp and possibly a 6J6 or 6U8 as the mixer and then it converting down to an IF frequency and its tube string , BUT, on the simplistic side of design, they merely may have converted to the sound IF frequency of 4.5 Mhz and that frequency is what one would normally expect the somewhat limited upper RF freq capacity of the 6AU6 to have been adequately processing.
That would also correlate in with your depicted diode as being the RF detector and then with its output being interfaced into the instruments Field Strength Meter driver circuitry.
1. Missing part? note leads coming thru tuner section. Underneath are two resistors tied together. They would not come thru the case unless there was another connection.
http://i294.photobucket.com/albums/mm95/johnfin1/guts009_mystery.jpg
Tuner:
http://i294.photobucket.com/albums/mm95/johnfin1/guts002_overall.jpg
http://i294.photobucket.com/albums/mm95/johnfin1/guts003_tuner.jpg
http://i294.photobucket.com/albums/mm95/johnfin1/guts004_tuner1.jpg
http://i294.photobucket.com/albums/mm95/johnfin1/guts013_tuner3.jpg
http://i294.photobucket.com/albums/mm95/johnfin1/guts008_tuner_input.jpg
METER:
http://i294.photobucket.com/albums/mm95/johnfin1/guts010_meter2.jpg
http://i294.photobucket.com/albums/mm95/johnfin1/guts011_6au6.jpg
http://i294.photobucket.com/albums/mm95/johnfin1/guts007_meter1.jpg
http://i294.photobucket.com/albums/mm95/johnfin1/guts006_meter.jpg
POWER:
http://i294.photobucket.com/albums/mm95/johnfin1/guts005_filters.jpg
http://i294.photobucket.com/albums/mm95/johnfin1/guts005_power.jpg
Another thing needing to be clarified is your mentioned “ two floating wires” of the tuner, as I didn’t readily see any from the photos, so if they are on the biggest photo that I marked up, point them out as their sector(s)to us on the supplied second grid layout just below. 1. ..A dedicated ground wire Now I can account for all of those at the top and the left side of the tuner, with the IF output being the terminal lug mounted at the top [ DD-18 ] sector and is utilizing an additional two sandwiched fiber washer insulators. There is no chance that those two wires are the ones at my red arrow marking. . . as the picture definition prohibits my seeing their termination axes. In the interim, if you want to start up troubleshooting again before giving me my required feed back info, and we are initially considering that a supply voltage evaluation has confirmed B + plusseseses being present at all plate and screen grids of the tubes and them having hotsy totsy filaments. Look at the tuner output and you will see it feeding into pin 1 first grid of the RF Amp-1 [Magenta reference A] and then being amplified and then passing its signal on into pin 1 first grid of the RF Amp-2 [Magenta reference B] and the signal finally being detected by the IN34 diode and being RF stripped with the resultant DC level then being applied to DC Meter Amplifier that is Soooooo, t..t…t..t…t take that seeeegnal genee-wator..a la Elmer Fudd . . .and come down on the band selector a couple of decades from your presently selected CHANNEL 2, and now think about either the 44 MHZ, 21 MHZ or 4.5 Mhz spectrum and with the best that I can see of those coils, but not TECHNICAL REFERENCING DATA:
In the referencing of the new crop of photos, I see that you invested in some illumination this time , and it seems that my guesstimation was right
on. . .as per that units utilization of a turret tuner and its tube complement of a 6BQ7 Cascode RF amp and a 6J6 mixer.
However I was some what surprised at the use of some Loktal / Octal ? ? ? power rectifier tube, as I was expecting the use of a companion 6X4 to go along with the miniature tube design lineup. Possibly, common surplus stock from an earlier companion instrument of that manufacturer, I guess.
It must be a 6 V rectifier unit, as I look at the power transformer and certainly can see the clipped off wires at my orange square markups [Grid Sectors F26,E27] that must be the 5V fil winding of the power transformer.(Just crying for 2 micro protective blobs of silicone rubber to be placed upon them for insulation !
That would then leave the filament of the rectifier tube with 6.3 VAC and that fil power is then additionally passed down thru my [4 blue squares] wire referencing, to then be feeding the sequentially daisy chained 6AU6[ DC Amplifier tube ] for the meter movement, the pilot lamp, the 6AU6 [ RF AMP-2], the 6AU6 [RF AMP-1],and then the [tuner tubes].
Now, can you confirm for us , that all of the three aforementioned tubes are 6AU6’s ? ? ?
For Tuner associative wiring / connections, I can see the need for :
2. ..1 filament wire
3. ..B+ supply line
4. ..Possible AGC input feed
5. ..Tuner output
located just behind the meter movement.
Somehow, I was expecting a dual triode akin to a 12AU7 being used in a Dual Differential DC Amplifier configuration for this function. . .BUT… I do seem to see that the existing tube 6AU6 (???) is screen to plate joined / configured for serving in a single triode utilization.
their resonating capacitors . . . .I tend to lean towards the 4.5 MHZ frequency, since one does not see any of the typical 6CB6 tube family being utilized for those two RF amp stages..
Initially, inject a tone modulated RF signal into the 1st grid of the second RF amp [magenta reference marked up box B]and sweeeeep across the aforementioned freqs to see if any meter deflection comes up on your unit and then, progressively increasing the RF input until you hopefully get a
reading and then sweeping the frequency will also let you zero in on the actual operating frequency of those stages.
Then you move RF signal injection on back to the 1st grid of the 1st RF amp stage and confirm the same, but with a requirement of but a fracion of that previously injected test signal level if there is gain in that stage.
Standing by. . . .
1- Looked at your A connection point with a scope, machine on, no rf. The freq on ch. 2 was 100mhz
2. Tried the freq's on all of the amp inputs, nothing
3. Tried 1vdc , machine off, at the inductor before the diode and the meter moved.
Tube voltages follows:
6bq7 pin1(27)pin6(0)pin7(28)pin8(28)
6j6 pin1(39)pin2(106)pin5(-.5)pin6(-.3)
6au6 pin1(-.7)pin5(125)pin6(84)
6cb6 pin1(-.7)pin5(27)pin6(118)pin7(0)
6au6(ear phone amp)pin1(0)pin6(111)pin7(2.5)
7Y4 pin7(227)
I am thinking the 6j6 osc. is off.
Now I can’t peruse the schemas fine points since it has EITHER been initially composed into too compressed of a pixel format or in the process of transferring between graphics processing mediums, it has ended up getting compressed excessively, but I really suspect the former. Now the good news. . . . . lets work with what I can make out from info supplied so far.
‘Bear’ with me, as yours will need a bit more perusing of your reverse engineered schematic that you have in progress. And BELIEVE me that is a repetitive process, with one initially getting all of the parts on the paper and then conforming all of the connections and then the transposing around of parts to look good on the schema layout and then the same thing again… until PERFECTION and more importantly ZER0 errors.
To wit, in the checking of the envelope of a vacuum tube I see that it is composed with a mere 35 pixel width, I use that as a minimum when I am drawing up a even a small transistor case. Preferably, a tube envelope should be I the order of 4-5 times that size shown.
(140-175 pix width /diameter) Since your resistors are also scaled proportionately, the resistor only shows up as 11 pix wide and I commonly use 50 pix.
We don’t even want to talk about the readability of any printing or labeling. And no, not even with all of my graphics enhancing and processing capabilities, can I pull out any greater resolution of what low density info that I am having to initially use.
Didn’t realize that unit had a dedicated ear phone driver also, supplementing the FS metering .
I think now that after reviewing what you described having done on the injected RF and its signal flow thru the system, it would now be in order to just initially concentrate on the R.F. amp stage that is feeding the next meter driver amp and then the frontal FS meter.
I can’t inspect those coils used in two stages to confirm their winding wires and sizes, but I still want to believe that they are using 4.5mhz, TV sound carrier frequency, with neither 44, or the ‘olde’ 22 MHZ TV IF frequencies even being involved in the system.
I will admit that 1N34 in your unit, was one of a pair that was stashed away by Noah from olden times, but initially lets lift one lead by heat sinking that lead close to the envelope by a firmly gripped pair of needle nose pliers or forceps then quickly unsoldering that lead and then, preferably use an old generation analog VOM to confirm that we still have in the order of a 10 to 1 front to back resistance ratio .
If your diode is still of usable F/B ratio and not having developed “germanium junctionitis” with time, put the unit back in place using the same heat sinking of the lead precaution.
Confirm that the cathode of that stage that we are working with has its cathode grounded, a hot filament and finally that it has somewhat of a norm of plate and screen voltage.
Now in consulting the mark up working schema, check out the area of interest boxed in as magenta and firstly, I hope that ? mark up ceramic capacitor shunting the 1N34 is of a low value.
And since we now know that we are working with a least a decent detector diode, to enhance our readings lets lift the circuitry. . . . to the left of the yellow X mark in. . . so that none of that meter loading circuitry to the left will be loading our detector any, as the other tied in loops are of adequately High Z.
Hook your signal generator into the red X input point and start out down below 4 MHZ and have a DVM in DC mode connected with ground to its neg lead and its positive lead connected into the negative junction of the 1N34, where you will then be expecting a negative swinging voltage being read upon signal detection.
Then you tune the generator across that generators decade seeking for a detected signal, if no signal, then up the RF drive level until you finally max out. . . .at some level you should start reading multi millivolts DC of detected signal, then you do a sweep to find the rough resonating point of that tuned RF L-C combo in the plate circuitry. You may find it on a higher or lower decade.
Lets do a pause at this point for the testing and then the feedback. . . . .
BTW. . .Unanswered ?'s from the past:
Do I understand that one of the plates of the 6BQ7 is without its plate voltage ?
Where were the two "loose " tuner wires mentioned, as per being located on the red grid layout ?
Your Schematic. . .Quasi /Psuedo enhanced ? and Marked up:
esign_Elements/Lines/blue_zig-zags.gif>
SRC=http://i294.photobucket.com/albums/mm95/johnfin1/a-465_light.jpg
I’m just gonna’ fill in below, so that I don’t overlook any topic nor fail to make queries on them:
Edd, here is an updated schematic. Well, with all of my digital enhancement magic and capabilities, I just can’t work out all aspects of the 1024 x791 You are injecting RF(or having RF come into that stage) into the 1st grid of that stage and then it is being amplified and shows up across the plate resistor (10k ?) of that stage and then the 100 pf cap couples into the tuned L-C pair and the RF ends up down at the cathode of the 1N34 detector diode and the, then rectified, RF coming from the diodes anode will be ending up across the summing capacitor (shown shooting up at the top to ground at the above right of the 4.7 k resistor going over to the metering).Best as I can make out it seems to be marked as a 106 unit which would be a 1 ufd unit. I also need the value of that capacitor which is shown shunting across the 1N34 diode. I was able to air couple a sig gen at 54 mhz I selected channel 2 on the meter and read a high plate value, at the 6cb6, 120vdc (27vdc without an RF signal). The meter deflected a 1/64". Then I stepped up the rf to channel 3, the meter followed it, so that part is working. If you are truly experiencing that is one BODACIOUS of a swing with signal / no signal conditions on the plate voltage. However, this circuitry is a bit different from the norm, with it using series resonant circuits instead of common parallel L-C tuned RF circuits. Now. . . Question. . . what did you report as the status on that 1N34’s “geranium” detector diodes front to back ratio evaluation, that I described ? Replaced every component in this machine and the results are the same. That’s a LOTS ‘a components ! Email me and will give you a decent schematic.
pixels J-peg that you posted on the site.
Per your last message,I fail to see how I am to measure DC voltage when there are two capacitors that block it.
With that RF presence, there will be rectification and developed negative voltage, as referenced to ground, that in addition to feeding your metering, it is also the source of the frontal AGC for the system. It zips down to the bottom thru the 470 k resistor and then is decoupled with a 1200 pfd bypass cap and then further dropped by another 470 k, with some more 1200 pfd decoupling action and then it branches upward thru a 100k? resistor to feed the 1st grid circuitry of the 6AU6 1st RF amp as well as the feed thru a 47k to control the gain of the cascode 6BQ7 RF amp in the tuner.
Now, I need clarification on that info, I am interpreting a read on that as you having loosely coupled /injected 54Mhz signal into the antenna terminals of the instrument, and not into the red arrow point that I had specified at the 6CB6’s grid input. . .PLUS. . .it would then have to be at the tuner input AS that 54mhz frequency would not be a viable frequency to be using on that 6CB6 stage, since the whole principle of the system is to use the tuner of the system to tune to a selected channels frequency, and that is then down converted to an Intermediate Frequency , with them either having opted for 44Mhz . . .or. . . down at 22 Mhz if this is old, first generation TV era equipment. . .OR. . .what I am thinking all of the time, with the viewing of the RF stages inductors, is that they are utilizing the sound frequency of 4.5 Mhz.
I can’t see channel 2 being SELECTED on the meter, but instead, can see the channel selector being switched to that channel or channel 3 as ws mentioned, with the units tuner.
With that great of a variance, there should be an equally high production of rectified DC from the 1N34 detector diode. OR do you, in reality, just have a DUD RF detector diode ?
I am about to contact you and be requesting same. . .’rat now. . .
Something about Dave's diagram that puzzles me is the tube that drives the meter circuit, a 6CB6. He shows what looks like a 100 ohm resistor and cap from pin 7 to ground/chassis. In a 6CB6 this pin is G3 + internal shield. Why would these components be placed there. However, if the tube were a 6AU6, then pin 7 is cathode. It would then make sense to me that the resistor and cap would provide bias for the stage.
:I’m just gonna’ fill in below, so that I don’t overlook any topic nor fail to make queries on them:
: Edd, here is an updated schematic.
:Well, with all of my digital enhancement magic and capabilities, I just can’t work out all aspects of the 1024 x791
:pixels J-peg that you posted on the site.
: Per your last message,I fail to see how I am to measure DC voltage when there are two capacitors that block it.
:You are injecting RF(or having RF come into that stage) into the 1st grid of that stage and then it is being amplified and shows up across the plate resistor (10k ?) of that stage and then the 100 pf cap couples into the tuned L-C pair and the RF ends up down at the cathode of the 1N34 detector diode and the, then rectified, RF coming from the diodes anode will be ending up across the summing capacitor (shown shooting up at the top to ground at the above right of the 4.7 k resistor going over to the metering).Best as I can make out it seems to be marked as a 106 unit which would be a 1 ufd unit. I also need the value of that capacitor which is shown shunting across the 1N34 diode.
:With that RF presence, there will be rectification and developed negative voltage, as referenced to ground, that in addition to feeding your metering, it is also the source of the frontal AGC for the system. It zips down to the bottom thru the 470 k resistor and then is decoupled with a 1200 pfd bypass cap and then further dropped by another 470 k, with some more 1200 pfd decoupling action and then it branches upward thru a 100k? resistor to feed the 1st grid circuitry of the 6AU6 1st RF amp as well as the feed thru a 47k to control the gain of the cascode 6BQ7 RF amp in the tuner.
:I was able to air couple a sig gen at 54 mhz
:Now, I need clarification on that info, I am interpreting a read on that as you having loosely coupled /injected 54Mhz signal into the antenna terminals of the instrument, and not into the red arrow point that I had specified at the 6CB6’s grid input. . .PLUS. . .it would then have to be at the tuner input AS that 54mhz frequency would not be a viable frequency to be using on that 6CB6 stage, since the whole principle of the system is to use the tuner of the system to tune to a selected channels frequency, and that is then down converted to an Intermediate Frequency , with them either having opted for 44Mhz . . .or. . . down at 22 Mhz if this is old, first generation TV era equipment. . .OR. . .what I am thinking all of the time, with the viewing of the RF stages inductors, is that they are utilizing the sound frequency of 4.5 Mhz.
:I selected channel 2 on the meter
:I can’t see channel 2 being SELECTED on the meter, but instead, can see the channel selector being switched to that channel or channel 3 as ws mentioned, with the units tuner.
:and read a high plate value, at the 6cb6, 120vdc (27vdc without an RF signal). The meter deflected a 1/64". Then I stepped up the rf to channel 3, the meter followed it, so that part is working.
:If you are truly experiencing that is one BODACIOUS of a swing with signal / no signal conditions on the plate voltage. However, this circuitry is a bit different from the norm, with it using series resonant circuits instead of common parallel L-C tuned RF circuits.
:Now. . . Question. . . what did you report as the status on that 1N34’s “geranium” detector diodes front to back ratio evaluation, that I described ?
:With that great of a variance, there should be an equally high production of rectified DC from the 1N34 detector diode. OR do you, in reality, just have a DUD RF detector diode ?
:Replaced every component in this machine and the results are the same.
:That’s a LOTS ‘a components !
:Email me and will give you a decent schematic.
:I am about to contact you and be requesting same. . .’rat now. . .
:73's de Edd:
OK, now after reworking that schema of the instrument. . . . and there were tons of digital trash hits on it, I just transposed it to a negative and that certainly got rid of the most of its problems. At least there will be no problem in consulting it now.
I was not worried about the use of any of the variants of the 6AU6 / 6CB6 / 6AK5 family in the units RF amplifier sections, but was instantly (within 'lebenteen femtoseconds ) keyed in on that capacitor that was shown across the detector diode.
If you will now consult the schematic below, I have color highlighted the different paths of interest .
The main one would be the downconverted signal from the Tuner IF output which is shown in [ LIME GREEN ], it then passes thru 2 stages of amplification and then ends up at the detector diode. But,and heavy on the BUT, now look at that diode and you will see that there is a .05 ufd capacitor shunting it. (After I finally got confirmation from you , as to what the exact value of that capacitor was )
Soooooo. . .That RF leval at that node is going to look around and see that companion .05 ufd cap, just to its right, and zip right on off to ground, with all amplified RF now being GONE.
Take dikes in hand and clip the left lead of that top yellow marked .05 ufd cap loose. And now, with your previously having mentioned seeing the FS meter move on upwards of 1/64's of an inch, it should really respond for you now now.
Upgrade me so I will then know to fill you in on alignment procedure.
Secondary information:
The [ORANGE] referenced buss is showing the feeding of the rectified DC down to the FSM's meter movement.
The [ BLUE-GREEN ] buss is showig the AGC voltage fed back to the 1st RF amp's 1st grid and then its drop
then being fed to the cascode RF amp in the tuner by the [BLUE-MAGENTA ] buss.
Finally, the [DARK GREEN] buss is feeding audio to its headphone driver amp.
MARKED UP REFERENCE SCHEMATIC:
