Atwater Kent model 42 filter caps?
11/8/2000 9:08:55 PMBud Geuvens
Having a problem with the filter caps on my model 42 AK. I clipped the ground to the caps and replaced the caps outside the "tar pot". I put one cap (1.0mfd)outside by the rectifier tube at the F1 wire and to ground. I put the other two on top, one filter cap(2.2mfd) at the +B,R.F. and the other by-pass cap (.5mfd)to the +B Det. and both to ground just like the schematics show. Now I have way to much B+ (335dc)at the terminal board at +B,R.F. and +B.2nd A.F. I put resistors inline to bring down the voltage in specs but I have a loud hum or ossilation at the speaker. I really don't know what the values are suppose to be for the caps. Any help would be appreciated.
Bud
11/9/2000 11:39:24 AMEd Kraushar
Hi, I looked up the schematic in a NRI manual and they show the caps as; R-f filament bypass (0.3 mfd @ 200 vdc)and R-f plate bypass (0.05 mfd @ 400v) in one can. Other caps are speaker filter (0.3 @ 450); detector phone (0.002 @ 500) and detector grid (0.00025 @ 500v).
I have not worked on this model but similar AK's had 2 filter chokes in the can along with the caps. Are you sure you have not bypassed the chokes. The filter chokes are listed as 1320 ohms total.
Ed.
11/9/2000 9:39:22 PMBud Geuvens
Hello Ed,
According to my Atwater book, the values differ than from the NRI manual. I have a NRI manual as well and the figures and names do not agree with the Atwater book that I have. According to it, the values should 1.5mfd on three filter caps and .5mfd on the two by-pass caps in the can. I haven't checked the ohms on the chokes as yet but will first thing tomorrow. The reason I replaced the caps to start with was the "tar bucket was getting hot so I checked the caps and found what looked like one was shorted. I might have more problems than with the caps being shorted but checking the ohms should tell me something.
Bud
