Help me please! :)
I don't know if it will help, but here's a spec sheet for the 6U5G:
http://www.mif.pg.gda.pl/homepages/frank/sheets/155/6/6U5.pdf
Carl T
:Hi, I have a 6U5G Brimar octal not like my other 6U5. And I don't know how to test it on my Heatkit TC-1 or Superior TV-11. And I know it's not a 1629 because I came near to toast it! The Heatkit can test the eye brightness but the Superior, I don't know. It's finally a 6.3V tube.
:Help me please! :)
VoilĂ ! :)
:Jeffy: BAMA has the set-up data for the Heath TC-2 (which also applies to TC-1). This page has the data for 6U5 (same as 6U5G):
:ftp://bama.sbc.edu/downloads/heath/tc-2/charts/tc2crt05.gif
:Doug
::Hi, I have a 6U5G Brimar octal not like my other 6U5. And I don't know how to test it on my Heatkit TC-1 or Superior TV-11. And I know it's not a 1629 because I came near to toast it! The Heatkit can test the eye brightness but the Superior, I don't know. It's finally a 6.3V tube.
::Help me please! :)
Best Regards,
Bill Grimm
:Hi Jeffy,
: The pin out of the 6U5G and 1629 are the same, the filament voltage is different. Your 6U5G will test like a 1629 EXCEPT that the filament is 6.3 volts, not 12.6 volts.
:Best Regards,
:Bill Grimm
: Jeffy, hi. I'm at a loss as to how the 6U5G you have is eight pin. The tube identifier I use comes out with six pin for 6U5, 6U5 G! How did you get the tube?
::Hi Jeffy,
:: The pin out of the 6U5G and 1629 are the same, the filament voltage is different. Your 6U5G will test like a 1629 EXCEPT that the filament is 6.3 volts, not 12.6 volts.
::Best Regards,
::Bill Grimm
